Hi @johannes_santos
Here is the translation of your request
"Hello colleagues, I am making some models for the content center and these have a factory reference that depends on 2 lengths, for this I made a small code that gives me the reference as a custom property. What happens is that it is an iPart that has two members and each one has a different parameter but they mean the same, in this case I would like the first line to be activated when I open the first member and the second line with the second member to that the reference only applies to the active member. I appreciate if anyone knows the solution"
Do you want to automate this process?
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
