I have an iLogic rule that can run in an out of date .dwg file and it will cross-check with the .dwg template file for any missing sketch symbols but I need to add some more functionality if possible.
What I want it to be able to do is to also copy over any folders containing sketch symbols in them over as well (see screenshot_1 from the template file vs screenshot_2 when the code is run). This code will copy the sketch symbols located in the sub folders however not the actual folder itself. Is this possible? The reason being - I will have over 20+ in this sub folder that I want to keep tidy. Some other things I would like to add -
- Can these be sorted in alphabetical order without deleting them all and re-adding them alphabetically?
-Can sketch symbols not found in the template be deleted out of the current .dwg file if they are also not being used on the current .dwg file (as to not delete the sketch symbol off the sheet if it is being used)
Below is my code currently:
Sub Main()
' Ensure the rule is running in a drawing document
If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
MessageBox.Show("This rule only works for Drawing Documents. Exiting.", "WRONG DOCUMENT TYPE", MessageBoxButtons.OK)
Return
End If
' Load the template drawing with updated sketch symbols
Dim templatePath As String = "TEMPLATE PATH HERE.dwg"
Dim templateDoc As DrawingDocument = ThisApplication.Documents.Open(templatePath, False)
Dim currentDoc As DrawingDocument = ThisDoc.Document
' Copy missing sketch symbols from template to current document
Dim templateSymbols As SketchedSymbolDefinitions = templateDoc.SketchedSymbolDefinitions
Dim currentSymbols As SketchedSymbolDefinitions = currentDoc.SketchedSymbolDefinitions
Dim missingSymbols As New List(Of String)
Dim importedSymbols As New List(Of String)
' Identify symbols that are in the template but not in the current document
For Each symDef In templateSymbols
If Not SymbolExists(currentSymbols, symDef.Name) Then
missingSymbols.Add(symDef.Name)
End If
Next
' Copy missing symbols to current document
For Each symName In missingSymbols
Dim symDef As SketchedSymbolDefinition = templateSymbols.Item(symName)
symDef.CopyTo(currentDoc, True)
importedSymbols.Add(symName)
Next
' Notify about imported symbols
If importedSymbols.Count > 0 Then
Dim message As String = "Imported symbols:" & vbCrLf & String.Join(vbCrLf, importedSymbols)
MessageBox.Show(message, "Symbols Imported")
Else
' MessageBox.Show("No new symbols were imported.", "Update Complete")
End If
' Clean up by closing the template without saving
templateDoc.Close(False)
' Optional: Reactivate the first sheet in the current document
If currentDoc.Sheets.Count > 0 Then
currentDoc.Sheets.Item(1).Activate()
End If
End Sub
Function SymbolExists(symbols As SketchedSymbolDefinitions, name As String) As Boolean
Try
Dim symbol As SketchedSymbolDefinition = symbols.Item(name)
Return symbol IsNot Nothing
Catch ex As Exception
Return False
End Try
End Function
Hi @chewy_robot. Are you aware that we do not need to keep all our SketchedSymbolDefinitions stored within our drawing templates, and that we can use an external SketchedSymbolDefinitionLibraries to store them in. I used to store tons of SketchedSymbolDefinitions in my template drawings also, but it was a real pain, and often required cleaning out all the ones I do not need later, which I did not like having to do. But then I discovered how the library system worked for these and that changed everything for the better. There is now a single DrawingDocument file stored outside of where we store our real templates, but still just under our Project file location, and within that DrawingDocument is this whole collection of SketchedSymbolDefinitions, all sorted and in multiple levels of sub folders. Our drawing templates now contain almost none of them, unless they are already being used on some sheets, within specialty multi-sheet drawing templates. Then when I make a new drawing from my template, and want to include / place any SketchedSymbols into any of my sheets, I just right-click on the Sketch Symbols folder (under the Drawing Resources folder in the model browser tree), even if there is nothing in that folder yet, and choose 'Insert'. That opens a dialog, which lets me either choose a 'local' resource, or one from within my SketchedSymbolDefinitionsLibrary. As simple as that. In the end, my new drawing only contains the ones I have inserted directly from the library (which copies the definition to the local document). And no unused ones to clean-up. No code required. Just putting that out there, in case it may be interesting or useful to you. But I may be able to help with the code side too, if still needed.
Wesley Crihfield
(Not an Autodesk Employee)
Thanks for the reply and for the info! This makes sense. However I am trying to eliminate clicks and I have this current rule as part of a "drawing updater" so to speak so I wanted to include this in there as part of a drawing clean up process just taking it a step further. Some people on my team are still unfamiliar with some Inventor processes so I am trying to keep things simple for them
Hi @chewy_robot. The good news is that I do believe that most, if not all, of what you would like to do is possible to do by code. However, the bad news is that some of it would be pretty complicated, and would require a whole lot more code, possibly doubling or tripling the size of your code. The step where you would like to eliminate local resources that are not being used, and are not found in the template sounds relatively easy to do. But finding sub folders within the model browser tree in the template, then creating those on the local side, then putting specific nodes into it, and making sure they are in alphabetical order is a whole other can of worms. I am not sure I would have time to tackle that right now myself, while I have several other projects going on.
Here is a version of your code which I tweaked slightly, and included the step where it eliminates 'local', unused resources that are not present in the template. One detail of my 'tweak' is eliminating the use of one code phrase to identify a document while doing the document type check, then using a different code phrase to identify a document when actually setting the value of the document variable to use in the code. That can lead to both pointing to different documents in some situations. This version is a little more direct, efficient, and safe. I reused your variable name though, so it would not mess anything else up. I just eliminated the Lists, message, and function to shorten the code a bit for posting the added process, since you already have them in your copy.
Sub Main()
Dim currentDoc As DrawingDocument = TryCast(ThisDoc.Document, Inventor.DrawingDocument)
If currentDoc Is Nothing Then
Return
End If
'Copy symbols from template that are not in the current document
For Each TSSDef As SketchedSymbolDefinition In templateSymbols
Dim bFoundLocally As Boolean = False
For Each LSSDef As SketchedSymbolDefinition In currentSymbols
If LSSDef.Name = TSSDef.Name Then
bFoundLocally = True
Exit For
End If
Next LSSDef
If Not bFoundLocally Then
TSSDef.CopyTo(currentDoc, True)
End If
Next TSSDef
'Delete unused symbols from current document that are not in the template
If LSSDef.IsReferenced Then Continue For 'skip to next symbol
Dim bFoundInTemplate As Boolean = False
bFoundInTemplate = True
Exit For
End If
Next TSSDef
If Not bFoundInTemplate Then LSSDef.Delete
Next LSSDef
'<<< code here to copy browser sub folders from template to current >>>
'<<< code here to put nodes into browser sub folder >>>
'<<< code here to sort nodes in sub folder alphabetically, if not put in that way >>>
End If
End Sub
Wesley Crihfield
