Do we have any possibilities to copy local form from the template to existing old drawing ?
I know that there is an option to use Global forms but this is not a case. I have multiple forms for each type of the template. If i place them all to Global templates it will case a mess for the users.
I created the topic previouslly where the question was posted in another way but I didn't got good answer. Maybe this will be better way to maintenance the forms.
Re: Global Forms depended on file extension - Autodesk Community - Inventor
Thanks in advance.
Solved by Lukasz.Dudkowski. Go to Solution.
Just found this topic. It isn’t supported in the API to copy forms from documents.
https://forums.autodesk.com/t5/inventor-customization/copy-form-to-other-files/td-p/9751986
A workaround might be to create a new drawing with updated forms and copy parameter by XML and sheets to new drawing. Effectively leave the form there and copy everything else.
I founded work around by my self.
For that purpose I used customized User Commands. Right now depending on active file and extension of it I can open from Tools tab requested Form with allows me to fill in needed metadata.
Two examples you can find in attachement.
