I try to use constrain-flush those part. I don`t know how to dim the face in part from assembly file. I appreciate any help!
Solved by JelteDeJong. Go to Solution.
Maybe this can help you. This code takes the first face of the 1e and 2e occurrence and use them for a flush constraint. I think you can test this the best with an assembly that contains 2 cubes.
Dim doc As AssemblyDocument = ThisDoc.Document Dim occ1 As ComponentOccurrence = doc.ComponentDefinition.Occurrences.Item(1) Dim occ2 As ComponentOccurrence = doc.ComponentDefinition.Occurrences.Item(2) Dim face1 As Face = occ1.SurfaceBodies.Item(1).Faces.Item(1) Dim face2 As Face = occ2.SurfaceBodies.Item(1).Faces.Item(1) Dim faceProxy1 As FaceProxy Dim faceProxy2 As FaceProxy occ1.CreateGeometryProxy(face1, faceProxy1) occ2.CreateGeometryProxy(face2, faceProxy2) doc.ComponentDefinition.Constraints.AddFlushConstraint(faceProxy1, faceProxy2, 0)
Jelte de Jong
Blog: hjalte.nl - github.com
