Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic - Straight VB Code - not seeing inventor dll
2 REPLIES 2
johnster100
341 Views, 2 Replies
I'm trying to create an external rule with some common functions I can call from other ilogic rules. To do this I've created the external rule, defined a class and selected straight vb code from the options:
Imports Inventor
Public Class Test
	Public Shared Sub Test()
		Dim oDrawDoc As Inventor.DrawingDocument
	End Sub
End Class
when I call the function from my ilogic rule I get the error:
Type 'Inventor.DrawingDocument' is not defined.
what am I doing wrong?
thanks for any help,
John
2 REPLIES 2
C-Hoppen
in reply to: johnster100
John
This works to me. Propably it can give you a hint.
Plain text from "Test.Vb"
' <IsStraightVb>True</IsStraightVb>
Imports System.Windows.Forms
Imports Inventor
Public Class Test
	Private Property ThisDoc As ICadDoc
	Public Sub New(thisDoc As ICadDoc)
		Me.ThisDoc = thisDoc
	End Sub
	Public Sub Main
		Dim oDrawDoc As DrawingDocument
		If ThisDoc.Document.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
			oDrawDoc = ThisDoc.Document
			MessageBox.Show(oDrawDoc.Sheets.Count, "No of Sheets")
		Else
			MessageBox.Show("Only for Drawing Documents!", "No Of Sheets")
	End Sub
End Class
Calling "Test.Main()" from another rule:
'Header --->
AddVbFile "C:\Users\chris\xxxxxxxxxxx\Test.vb"
'<--- Header
Dim test As New Test(ThisDoc)
test.Main()
Regards
Christoph
Update: tested with Inventor 2021.3 Build 353
johnster100
in reply to: C-Hoppen
thanks for the reply 🙂
works 🙂
Technology Administrators
