combining text and parameter in ilogic
Geertvdheide92
Geertvdheide92
I am trying to combine a parameter and text in ilogic if then statement.
the code is saying ')'excpected.
the code i'm using is this:
SyntaxEditor Code Snippet
If Standard=1 Then
Size= (Size_2, "In")
ElseIf Standard=2 Then
Size=(Size_2,"mm")
End If
 Size_2 is defined using a excel sheet.
I set the parameter property format to 0 decimals and no units showing.
So if standard 1 and size_2 is 6mm
In NXTdim the property Size should show 6 in
Or can i edit the formula of "Size" using a formula in custom properties
for example Size= <Size_2> <unit>
but i cant export a text format to custom properties, so not sure if this is possible.
is there a simple option for this issue?
kind regards
bradeneuropeArthur
I assume you are Dutch Op based Van NXTDIM?
Could you please explain:
Standard:  is a parameter or a property and comes from excel
Size: is a parameter or a property and comes from excel
Size_2: is a parameter or a property and comes from excel
Standard :is a parameter or a property and comes from excel.
kun je wat meer details geven mbt je wil doen.
Ik begrijp niet helemaal wat je wil doen.
Misschien dat nederlands helpt!!
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Geertvdheide92
yes im dutch,
i continue in english so it may help other people
I want to describe the size of a part.
Depending on the values i get from my excel the units should say "in" or "mm"
in my  case the standard and size are values i put in inventor, so i get multiple values from excel.
depending on only the standard value i want to change the units described in the Size.
currently i found a workaround that works fine.
the code is:
If Standard=1 Then
iProperties.Value("Custom","A")=GoExcel.CurrentRowValue("A_1")
iProperties.Value("Custom","B")=""
iProperties.Value("Custom","A")=""
iProperties.Value("Custom","B")=GoExcel.CurrentRowValue("B_1")
End If
in Excel column A has the value "in" and Column B has the value"mm"
next in custom properties for Size i have the formula
Size= <Size_2><A><B>
so if standard=1 then A= in and B is empty
this way i can combine numbers and text in the custom properties.
bradeneuropeArthur
So may I understand you solved it yourselves?
Arthur Knoors
bradeneuropeArthur
Could be a little bit shorter and less code:
If Standard=1 Then
iProperties.Value("Custom","Size")=Size_2.Value  & GoExcel.CurrentRowValue("A_1")
iProperties.Value("Custom","Size")=Size_2.Value  & GoExcel.CurrentRowValue("B_1")
End If
If Standard=1 Then
iProperties.Value("Custom","Size")= Parameter.Param("Size_2").Value & GoExcel.CurrentRowValue("A_1")
iProperties.Value("Custom","Size")= Parameter.Param("Size_2").Value & GoExcel.CurrentRowValue("B_1")
End If
Arthur Knoors
Geertvdheide92
Ah thank you,
this is indeed the way i was trying to find to combine 2 different types of parameters.
bradeneuropeArthur
Maybe it could be easier without Excel if you want too!
Arthur Knoors
