Change the text size in the Styles Editor using VBA
shastu
Advisor Advisor
Message 1 of 21
shastu
This should be so simple, but I can't figure out how to do it.  All I want to do is change the Text Height of "DEFAULT-ANSI" using VBA for the active drawing file.  See screenshot.
Sub TextSize()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet.
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    ' Code to change the Text Height from 0.120 to .080.
End Sub
Replies (20)
Message 21 of 21
A.Acheson
Go to all forums at the bottom of the page and navigate to Autocad. Here you will need to select which forum you want link here. Also if you perform an Internet search with VBA Autocad and the task you want you should get direct hits to the AutocadForum that involve coding and VBA.
Regards
Alan
