Change FastenerSize of HoleClearanceInfo
wolfgang_nickl
Message 1 of 8
wolfgang_nickl
Hello together,
I want to Change a Holedefinition of a Clearance  Hole.
I can query the current size. In API docu it is descript as Read-write,
but I can't set a new value. Open the attached file or any part with
a clearance hole and start the Sub below. The first Messagebox shows
the Size but it results in an error when I try to set a new value.
What is wrong?
Sub subWNHolefeatureUpdate()
    Dim oWNPartDoc As PartDocument
    Set oWNPartDoc = ThisApplication.ActiveDocument
    Dim oWNHoleFeature As HoleFeature
    For Each oWNHoleFeature In oWNPartDoc.ComponentDefinition.Features.HoleFeatures
        MsgBox oWNHoleFeature.ClearanceInfo.FastenerSize
        On Error Resume Next
            oWNHoleFeature.ClearanceInfo.FastenerSize = "M6"
        MsgBox Err.Description
    Next
End Sub
Best Regards
Wolfgang
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@wolfgang_nickl,
Unfortunately, properties of HoleClearanceInfo for HoleFeature are read only. Please log this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
HermJan.Otterman
I think you need to create a new ClearanceInfo...
you should be able to do this with:
Dim mhtns As ModelHoleThreadNotes = oPartCompDef.ModelAnnotations.ModelHoleThreadNotes
Dim newholeclinfo As HoleClearanceInfo = Nothing
 newholeclinfo = mhtns.CreateClearanceInfo("DIN" , "Countersunk Flat Head Screw DIN EN ISO 2009" , "M6")
and then replace the complete HoleClearanceInfo
but if you try to get the holeClearanceinfo.FastenerStandard from the hole you already created it gives an error....
and also creating the new one does not work.
with me trying to figure this out, my Inventor (2018.2.3) is crashing constantly, so I gues Autodesk have to fix things
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 4 of 8
marcin_otręba
It can be done differently,
Look for clearance.xls in your style folder, you can read values from it to get fastener size and corresponding diameters.
Give to user fasteners sizes in combo, and when he choose one, your script will change hole diameter looking for corresponding one to chosen fastener.
use something like:
    Set oWNHoleFeature = oWNPartDoc.ComponentDefinition.Features.HoleFeatures.Item(1)
       'oWNHoleFeature.HoleDiameter.Value = 10 ' in cm - corresponding value read from xls
       oWNHoleFeature.HoleDiameter.Expression = "6,6"  - corresponding value read from xls
       oWNPartDoc.Update
End Sub
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders   auto-save-replace
Message 5 of 8
wolfgang_nickl
Hello Jan,
ModelAnnotations I think is the wrong point.
I want to change the size of the clearancehole and not
the 3D dimensions.
Best Regards
Wolfgang
Message 6 of 8
HermJan.Otterman
according to the Inventor Help, you should be able with this to edit the HoleFeature object
Herm Jan
Message 7 of 8
wolfgang_nickl
Hello Marcin,
its a workaround for a simple hole,
but if you have to distinguish countersinks it
isn't that easy. You have to set more then one
Value and it's not the same for cylindric and
cone sink.
I think Autodesk should make the value writeable.
Anyway thank you for your solution in special circumstances it will
work for me.
Best Regards
Wolfgang
Message 8 of 8
marcin_otręba
i think it is only more complex approach... idk what you're working at but you must decide if it is worth it... sadly i don't know any other way to do it (beside complex ifeature)...
Ideas
or check my apps:
