Can´t see the family in Bolted connection, why
Darkforce_the_ilogic_guy
Advisor Advisor
I am working on creating some custom family. But for some reasom my Hex Head Screw family does not show in Bolted Connection. why could this be ?
bradeneuropeArthur
Because the bolted connection is a assembly of families, not only one and the same, maybe!?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
It seens that the problem was that the current size was not a part of the familie ...  and when that is .. you can´t see theat familie
I find out that the hole I was teste it in was for a M10 bolt ... but I have only made bolt in the famile form M16 and up.. I did not know that the familie would not show if that right size was not a part of the family
