Can a drawing have more than one "DrawingBom"
bradeneuropeArthur
bradeneuropeArthur
Is it possible to have more DrawingBoms in one drawing?
Via the API you have the object DrawingBoms which suggest multiple.
ThisDrawing.Document.DrawingBOMs.Count
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
CCarreiras
Hi!
You can gave more then one, with different filters applied, but... all of the same type:
all lists type "STRUTURED", or all lists type "PARTS ONLY".
Ex:
CCarreiras
bradeneuropeArthur
@CCarreiras means all the same DrawingBom.
And DrawingBoms.Count will always return "1"
Correct?
Arthur Knoors
Michael.Navara
You can get more than one DrawingBOM if you create drawing with more than one base views from different models with its partsLists
See the sample in attachment
