I am trying to write a print rule that prints a set of drawings for our design releases. The way I have gone about this is to open every drawing that I need printed and hit the button. Then the rule puts the prints in the correct order and prints the correct qty (1 – A, 3 – B, 1-D). this is what our shop is used to getting. This has been working very well. The have requested a plot stamp that has the date and time that the print was issued. This is something that has been done manually and I was trying to automat it with the print rule. Below is the rule that I have put together. I am not a programmer and much of this is cut and paste from this forum.
My problem is I am adding the plot stamp to each drawing then plotting then deleting the plot stamp. This works like a charm if I do one drawing at a time but when I loop through the drawings it adds the plot stamp to all drawings but only deletes the stamp from the last drawing plotted. If anyone has any idea how I can improve this to make it work, I could sure use the help.
Sub main() Dim VisDocs As DocumentsEnumerator VisDocs = ThisApplication.Documents.VisibleDocuments Dim Count As Integer Count = VisDocs.Count Dim Arr(0 To Count) As String For i = 1 To Count Arr(i) = VisDocs.Item(i).fullDocumentName Next i For i = 1 To UBound(Arr) For j = i + 1 To UBound(Arr) If (Arr(i)) < (Arr(j)) Then temp = Arr(j) Arr(j) = Arr(i) Arr(i) = temp End If Next j Next i PrintQty = 1 PrintNo = 1 While PrintQty >= PrintNo For i = 1 To Count oDoc = ThisApplication.Documents.Open(Arr(i), False) If (oDoc.DocumentType = kDrawingDocumentObject) Then Call AddNote() oDoc.Activate Dim oDrawDoc As Document oDrawDoc = ThisApplication.ActiveDocument Dim oPrintMgr As DrawingPrintManager oPrintMgr = oDrawDoc.PrintManager With oPrintMgr .Printer = "HP DesignJet T930 PS HPGL2" .PrintRange = PrintRangeEnum.kPrintAllSheets .ColorMode = PrintColorModeEnum.kPrintDefaultColorMode .NumberOfCopies = 1 .Orientation = PrintOrientationEnum.kLandscapeOrientation .ScaleMode = PrintScaleModeEnum.kPrintBestFitScale .PaperSize = PaperSizeEnum.kPaperSizeDSheet .SubmitPrint 'MessageBox.Show(Arr(i), "Print D") End With 'MessageBox.Show(Arr(i)+ " print " + CStr(PrintNo)+ " on printer " + oPrintMgr.Printer, "Print Test") Call DeleteNote() End If Next i PrintNo = PrintNo + 1 End While For i = 1 To UBound(Arr) For j = i + 1 To UBound(Arr) If (Arr(i)) > (Arr(j)) Then temp = Arr(j) Arr(j) = Arr(i) Arr(i) = temp End If Next j Next i PrintQty = 3 PrintNo = 1 While PrintQty >= PrintNo For i = 1 To Count oDoc = ThisApplication.Documents.Open(Arr(i), False) If (oDoc.DocumentType = kDrawingDocumentObject) Then Call AddNote() oDoc.Activate Dim oDrawDoc As Document oDrawDoc = ThisApplication.ActiveDocument Dim oPrintMgr As DrawingPrintManager oPrintMgr = oDrawDoc.PrintManager With oPrintMgr .Printer = "\\HCC-APPS\XEROX" .PrintRange = PrintRangeEnum.kPrintAllSheets .ColorMode = PrintColorModeEnum.kPrintDefaultColorMode .NumberOfCopies = 1 .Orientation = PrintOrientationEnum.kLandscapeOrientation .ScaleMode = PrintScaleModeEnum.kPrintBestFitScale .PaperSize = PaperSizeEnum.kPaperSize11x17 .SubmitPrint 'MessageBox.Show(Arr(i), "Print B") End With 'MessageBox.Show(Arr(i)+ " print " + CStr(PrintNo)+ " on printer " + oPrintMgr.Printer, "Print Test") Call DeleteNote() End If Next i PrintNo = PrintNo + 1 End While PrintQty = 1 PrintNo = 1 While PrintQty >= PrintNo For i = 1 To Count oDoc = ThisApplication.Documents.Open(Arr(i), False) If (oDoc.DocumentType = kDrawingDocumentObject) Then Call AddNote() oDoc.Activate Dim oDrawDoc As Document oDrawDoc = ThisApplication.ActiveDocument Dim oPrintMgr As DrawingPrintManager oPrintMgr = oDrawDoc.PrintManager With oPrintMgr .Printer = "\\HCC-APPS\XEROX" .PrintRange = PrintRangeEnum.kPrintAllSheets .ColorMode = PrintColorModeEnum.kPrintDefaultColorMode .NumberOfCopies = 1 .Orientation = PrintOrientationEnum.kLandscapeOrientation .ScaleMode = PrintScaleModeEnum.kPrintBestFitScale .PaperSize = PaperSizeEnum.kPaperSizeLetter .SubmitPrint 'MessageBox.Show(Arr(i), "Print A") End With 'MessageBox.Show(Arr(i)+ " print " + CStr(PrintNo)+ " on printer " + oPrintMgr.Printer, "Print Test") Call DeleteNote() End If Next i PrintNo = PrintNo + 1 End While End Sub Sub AddNote() Dim AddNoteinvApp As Inventor.Application AddNoteinvApp = ThisApplication Dim AddNoteoDrawDoc As Document AddNoteoDrawDoc = AddNoteinvApp.ActiveEditDocument Dim UserStr As String Dim dateStr As Date Dim PlotStamp As String dateStr = Now UserStr = ThisApplication.GeneralOptions.UserName PlotStamp = UserStr +" "+dateStr Dim AddNoteoTG As Inventor.TransientGeometry = AddNoteinvApp.TransientGeometry For Each AddNoteoSheet In AddNoteoDrawDoc.Sheets AddNoteoNote = AddNoteoSheet.DrawingNotes.GeneralNotes.AddFitted(AddNoteoTG.CreatePoint2d(.5,4), PlotStamp) With AddNoteoNote .Rotation = (PI/2)+.001 'radianti .LineSpacing = .8125 .VerticalJustification = Inventor.VerticalTextAlignmentEnum.kAlignTextMiddle .HorizontalJustification = Inventor.HorizontalTextAlignmentEnum.kAlignTextLeft .FormattedText = "<StyleOverride FontSize = '.25'>" & PlotStamp & "</StyleOverride>" End With AddNoteoDrawDoc.Update() Next End Sub Sub DeleteNote() Dim DeleteNoteinvApp As Inventor.Application DeleteNoteinvApp = ThisApplication Dim DeleteNoteoDrawDoc As Document DeleteNoteoDrawDoc = DeleteNoteinvApp.ActiveEditDocument For Each oSheet In DeleteNoteoDrawDoc.Sheets For Each oGeneralNote In oSheet.DrawingNotes.GeneralNotes If oGeneralNote.Rotation = (PI/2)+.001 oGeneralNote.Delete End If Next Next End Sub
Solved by Sergio.D.Suárez. Go to Solution.
Hi, Actually, I did not understand the procedure well, but I modified its code a bit to eliminate some lines that seemed to me with errors. To begin instead of the order to open a hidden file in a hidden mode, I directly perform actions, add note, print, delete the note, and then I close it (without saving) and move on to the next one.
Making the same modification for the remaining visible files. I think it is important to activate and deactivate each work file properly so that the rule add note and delete note act on the active documents that correspond to them.
I hope it will be useful. regards
Sub Main() Dim VisDocs As DocumentsEnumerator VisDocs = ThisApplication.Documents.VisibleDocuments Dim Count As Integer Count = VisDocs.Count Dim Arr(0 To Count) As String For i = 1 To Count Arr(i) = VisDocs.Item(i).fullDocumentName Next i For i = 1 To UBound(Arr) For j = i + 1 To UBound(Arr) If (Arr(i)) < (Arr(j)) Then temp = Arr(j) Arr(j) = Arr(i) Arr(i) = temp End If Next j Next i PrintQty = 1 PrintNo = 1 While PrintQty >= PrintNo For i = 1 To Count oDoc = ThisApplication.Documents.VisibleDocuments.Item(i) If (oDoc.DocumentType = kDrawingDocumentObject) Then oDoc.Activate Call AddNote() Dim oPrintMgr As DrawingPrintManager oPrintMgr = oDoc.PrintManager With oPrintMgr .Printer = "HP DesignJet T930 PS HPGL2" .PrintRange = PrintRangeEnum.kPrintAllSheets .ColorMode = PrintColorModeEnum.kPrintDefaultColorMode .NumberOfCopies = 1 .Orientation = PrintOrientationEnum.kLandscapeOrientation .ScaleMode = PrintScaleModeEnum.kPrintBestFitScale .PaperSize = PaperSizeEnum.kPaperSizeDSheet .SubmitPrint 'MessageBox.Show(Arr(i), "Print D") End With 'MessageBox.Show(Arr(i)+ " print " + CStr(PrintNo)+ " on printer " + oPrintMgr.Printer, "Print Test") Call DeleteNote() oDoc.close End If Next i PrintNo = PrintNo + 1 End While For i = 1 To UBound(Arr) For j = i + 1 To UBound(Arr) If (Arr(i)) > (Arr(j)) Then temp = Arr(j) Arr(j) = Arr(i) Arr(i) = temp End If Next j Next i PrintQty = 3 PrintNo = 1 While PrintQty >= PrintNo For i = 1 To Count oDoc = ThisApplication.Documents.VisibleDocuments.Item(i) If (oDoc.DocumentType = kDrawingDocumentObject) Then oDoc.Activate Call AddNote() Dim oPrintMgr As DrawingPrintManager oPrintMgr = oDoc.PrintManager With oPrintMgr .Printer = "\\HCC-APPS\XEROX" .PrintRange = PrintRangeEnum.kPrintAllSheets .ColorMode = PrintColorModeEnum.kPrintDefaultColorMode .NumberOfCopies = 1 .Orientation = PrintOrientationEnum.kLandscapeOrientation .ScaleMode = PrintScaleModeEnum.kPrintBestFitScale .PaperSize = PaperSizeEnum.kPaperSize11x17 .SubmitPrint 'MessageBox.Show(Arr(i), "Print B") End With 'MessageBox.Show(Arr(i)+ " print " + CStr(PrintNo)+ " on printer " + oPrintMgr.Printer, "Print Test") Call DeleteNote() oDoc.close End If Next i PrintNo = PrintNo + 1 End While PrintQty = 1 PrintNo = 1 While PrintQty >= PrintNo For i = 1 To Count oDoc = ThisApplication.Documents.VisibleDocuments.Item(i) If (oDoc.DocumentType = kDrawingDocumentObject) Then oDoc.Activate Call AddNote() Dim oPrintMgr As DrawingPrintManager oPrintMgr = oDoc.PrintManager With oPrintMgr .Printer = "\\HCC-APPS\XEROX" .PrintRange = PrintRangeEnum.kPrintAllSheets .ColorMode = PrintColorModeEnum.kPrintDefaultColorMode .NumberOfCopies = 1 .Orientation = PrintOrientationEnum.kLandscapeOrientation .ScaleMode = PrintScaleModeEnum.kPrintBestFitScale .PaperSize = PaperSizeEnum.kPaperSizeLetter .SubmitPrint 'MessageBox.Show(Arr(i), "Print A") End With 'MessageBox.Show(Arr(i)+ " print " + CStr(PrintNo)+ " on printer " + oPrintMgr.Printer, "Print Test") Call DeleteNote() oDoc.Close End If Next i PrintNo = PrintNo + 1 End While End Sub Sub AddNote() Dim AddNoteinvApp As Inventor.Application AddNoteinvApp = ThisApplication Dim AddNoteoDrawDoc As Document AddNoteoDrawDoc = AddNoteinvApp.ActiveEditDocument Dim UserStr As String Dim dateStr As Date Dim PlotStamp As String dateStr = Now UserStr = ThisApplication.GeneralOptions.UserName PlotStamp = UserStr +" "+dateStr Dim AddNoteoTG As Inventor.TransientGeometry = AddNoteinvApp.TransientGeometry For Each AddNoteoSheet In AddNoteoDrawDoc.Sheets AddNoteoNote = AddNoteoSheet.DrawingNotes.GeneralNotes.AddFitted(AddNoteoTG.CreatePoint2d(.5,4), PlotStamp) With AddNoteoNote .Rotation = (PI/2)+.001 'radianti .LineSpacing = .8125 .VerticalJustification = Inventor.VerticalTextAlignmentEnum.kAlignTextMiddle .HorizontalJustification = Inventor.HorizontalTextAlignmentEnum.kAlignTextLeft .FormattedText = "<StyleOverride FontSize = '.25'>" & PlotStamp & "</StyleOverride>" End With AddNoteoDrawDoc.Update() Next End Sub Sub DeleteNote() Dim DeleteNoteinvApp As Inventor.Application DeleteNoteinvApp = ThisApplication Dim DeleteNoteoDrawDoc As Document DeleteNoteoDrawDoc = DeleteNoteinvApp.ActiveEditDocument For Each oSheet In DeleteNoteoDrawDoc.Sheets For Each oGeneralNote In oSheet.DrawingNotes.GeneralNotes If oGeneralNote.Rotation = (PI/2)+.001 oGeneralNote.Delete End If Next Next End Sub
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank you for reviewing my work. I used the open instead of visible because i had to sort the files by filename. I do not know how to read the visible.item() and set it to a veritable. After testing your modifications, the files were being printed in the order they were opened and not in the order of file name A to Z on one printer and Z to A on the other, So i returned to the open. One item that i was missing was the .close after each file in the loop. After adding this it looks as if it works like a charm. I did some cleanup in my code as well and this is what my final code looks like.
If you could tell me how to sort my files by name and get the files to come up in order A to Z using the .item() i would love to learn from your experience!!!
Sub Main() Dim VisDocs As DocumentsEnumerator VisDocs = ThisApplication.Documents.VisibleDocuments Dim Count As Integer Count = VisDocs.Count Dim Arr(0 To Count) As String For i = 1 To Count Arr(i) = VisDocs.Item(i).fullDocumentName Next i 'Getting the sheets in the order they should be printed Z to A For i = 1 To UBound(Arr) For j = i + 1 To UBound(Arr) If (Arr(i)) < (Arr(j)) Then temp = Arr(j) Arr(j) = Arr(i) Arr(i) = temp End If Next j Next i PrintQty = 1 '# of of prints required PrintNo = 1 '# being printed While PrintQty >= PrintNo For i = 1 To Count oDoc = ThisApplication.Documents.Open(Arr(i), False) If (oDoc.DocumentType = kDrawingDocumentObject) Then oDoc.Activate Call AddNote() Paper = PaperSizeEnum.kPaperSizeLetter Call Plot(oDoc, Paper) Call DeleteNote() oDoc.close End If Next i PrintNo = PrintNo + 1 End While 'Getting the sheets in the order they should be printed A to Z For i = 1 To UBound(Arr) For j = i + 1 To UBound(Arr) If (Arr(i)) > (Arr(j)) Then temp = Arr(j) Arr(j) = Arr(i) Arr(i) = temp End If Next j Next i PrintQty = 3 '# of of prints required PrintNo = 1 '# being printed While PrintQty >= PrintNo For i = 1 To Count oDoc = ThisApplication.Documents.Open(Arr(i), False) If (oDoc.DocumentType = kDrawingDocumentObject) Then oDoc.Activate Call AddNote() Paper = PaperSizeEnum.kPaperSize11x17 Call Plot(oDoc, Paper) Call DeleteNote() oDoc.close End If Next i PrintNo = PrintNo + 1 End While PrintQty = 1 '# of of prints required PrintNo = 1 '# being printed While PrintQty >= PrintNo For i = 1 To Count oDoc = ThisApplication.Documents.Open(Arr(i), False) If (oDoc.DocumentType = kDrawingDocumentObject) Then oDoc.Activate Call AddNote() Paper = PaperSizeEnum.kPaperSizeDSheet Call Plot(oDoc, Paper) Call DeleteNote() oDoc.close End If Next i PrintNo = PrintNo + 1 End While End Sub Sub AddNote() 'add plot stamp Dim AddNoteinvApp As Inventor.Application AddNoteinvApp = ThisApplication Dim AddNoteoDrawDoc As Document AddNoteoDrawDoc = AddNoteinvApp.ActiveEditDocument Dim UserStr As String Dim dateStr As Date Dim PlotStamp As String dateStr = Now UserStr = ThisApplication.GeneralOptions.UserName PlotStamp = UserStr +" "+dateStr Dim AddNoteoTG As Inventor.TransientGeometry = AddNoteinvApp.TransientGeometry For Each AddNoteoSheet In AddNoteoDrawDoc.Sheets AddNoteoNote = AddNoteoSheet.DrawingNotes.GeneralNotes.AddFitted(AddNoteoTG.CreatePoint2d(.5,4), PlotStamp) With AddNoteoNote .Rotation = (PI/2)+.001 'radianti .LineSpacing = .8125 .VerticalJustification = Inventor.VerticalTextAlignmentEnum.kAlignTextMiddle .HorizontalJustification = Inventor.HorizontalTextAlignmentEnum.kAlignTextLeft .FormattedText = "<StyleOverride FontSize = '.1875'>" & PlotStamp & "</StyleOverride>" End With AddNoteoDrawDoc.Update() Next End Sub Sub DeleteNote() 'remove plot stamp Dim DeleteNoteinvApp As Inventor.Application DeleteNoteinvApp = ThisApplication Dim DeleteNoteoDrawDoc As Document DeleteNoteoDrawDoc = DeleteNoteinvApp.ActiveEditDocument For Each oSheet In DeleteNoteoDrawDoc.Sheets For Each oGeneralNote In oSheet.DrawingNotes.GeneralNotes If oGeneralNote.Rotation = (PI/2)+.001 oGeneralNote.Delete End If Next Next End Sub Sub Plot(oDoc, Paper) 'runs the prints Dim oPrintMgr As DrawingPrintManager oPrintMgr = oDoc.PrintManager With oPrintMgr .Printer = "\\HCC-APPS\XEROX" .PrintRange = PrintRangeEnum.kPrintAllSheets .ColorMode = PrintColorModeEnum.kPrintDefaultColorMode .NumberOfCopies = 1 .Orientation = PrintOrientationEnum.kLandscapeOrientation .ScaleMode = PrintScaleModeEnum.kPrintBestFitScale .PaperSize = Paper '.SubmitPrint End With End Sub
Hello, first of all, I am also an apprentice, I am like your researcher and the doubts that arise also I learn.
Try to make a code that alphabetically orders open documents and this small segment seems to work.
Dim VisDocs As DocumentsEnumerator VisDocs = ThisApplication.Documents.VisibleDocuments Dim Count As Integer Count = VisDocs.Count '--------------------------------------------------- Dim AlphaOrder As New ArrayList For i = 1 To Count AlphaOrder.Add(VisDocs.Item(i).displayname) Next i AlphaOrder.Sort() For i = 0 To Count - 1 MessageBox.Show(AlphaOrder(i)) Next i
I have not tested it in its entirety, I think it could be added to your code, maybe correcting it in this way.
I hope it works. I'm sure there will be simpler methods and maybe more practical, if I can find some I'll leave it here. regards
Dim VisDocs As DocumentsEnumerator VisDocs = ThisApplication.Documents.VisibleDocuments Dim Count As Integer Count = VisDocs.Count '--------------------------------------------------- Dim AlphaOrder As New ArrayList For i = 1 To Count AlphaOrder.Add(VisDocs.Item(i).displayname) Next i AlphaOrder.Sort() '-------------------------------------------------- Dim Arr(0 To Count) As String For i = 1 To Count Filename = AlphaOrder(i - 1) For j = 1 To Count If VisDocs.Item(j).Displayname = Filename Then Arr(j) = VisDocs.Item(j).fullDocumentName Exit For End If Next j Next i For i = 1 To UBound(Arr) For j = i + 1 To UBound(Arr) If (Arr(i)) < (Arr(j)) Then temp = Arr(j) Arr(j) = Arr(i) Arr(i) = temp End If Next j Next i
Mechanical Designer
