Batch plot with plot stamp.
3 REPLIES 3
ACritchelow
596 Views, 3 Replies
ACritchelow
I am trying to write a print rule that prints a set of drawings for our design releases. The way I have gone about this is to open every drawing that I need printed and hit the button. Then the rule puts the prints in the correct order and prints the correct qty (1 – A, 3 – B, 1-D). this is what our shop is used to getting. This has been working very well. The have requested a plot stamp that has the date and time that the print was issued. This is something that has been done manually and I was trying to automat it with the print rule. Below is the rule that I have put together. I am not a programmer and much of this is cut and paste from this forum.
My problem is I am adding the plot stamp to each drawing then plotting then deleting the plot stamp. This works like a charm if I do one drawing at a time but when I loop through the drawings it adds the plot stamp to all drawings but only deletes the stamp from the last drawing plotted. If anyone has any idea how I can improve this to make it work, I could sure use the help.
Sub main()
	Dim VisDocs As DocumentsEnumerator
	VisDocs = ThisApplication.Documents.VisibleDocuments
	Dim Count As Integer
	Count = VisDocs.Count
	Dim Arr(0 To Count) As String
	For i = 1 To Count
	    Arr(i) = VisDocs.Item(i).fullDocumentName
	Next i
	For i = 1 To UBound(Arr)
	    For j = i + 1 To UBound(Arr)
	        If (Arr(i)) < (Arr(j)) Then
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
	PrintQty = 1
	PrintNo = 1
	While PrintQty >= PrintNo
		For i = 1 To Count
			oDoc = ThisApplication.Documents.Open(Arr(i), False)
			If (oDoc.DocumentType = kDrawingDocumentObject) Then
				Call AddNote()
				oDoc.Activate
				Dim oDrawDoc As Document
				oDrawDoc = ThisApplication.ActiveDocument
				Dim oPrintMgr As DrawingPrintManager
				oPrintMgr = oDrawDoc.PrintManager
				With oPrintMgr
					.Printer = "HP DesignJet T930 PS HPGL2"
					.PrintRange = PrintRangeEnum.kPrintAllSheets
					.ColorMode = PrintColorModeEnum.kPrintDefaultColorMode
					.NumberOfCopies = 1
					.Orientation = PrintOrientationEnum.kLandscapeOrientation
					.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale
					.PaperSize = PaperSizeEnum.kPaperSizeDSheet
					.SubmitPrint
					'MessageBox.Show(Arr(i), "Print D")
				End With
				'MessageBox.Show(Arr(i)+ " print " + CStr(PrintNo)+ " on printer " + oPrintMgr.Printer, "Print Test")
				Call DeleteNote()
			End If
		Next i
	PrintNo = PrintNo + 1
	End While
	        If (Arr(i)) > (Arr(j)) Then
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
	PrintQty = 3
	PrintNo = 1
		For i = 1 To Count
				Call AddNote()
				oDoc.Activate
				With oPrintMgr
					.Printer = "\\HCC-APPS\XEROX"
					.NumberOfCopies = 1
					.PaperSize = PaperSizeEnum.kPaperSize11x17
					.SubmitPrint
					'MessageBox.Show(Arr(i), "Print B")
				End With
				Call DeleteNote()
			End If
		Next i
	End While
	PrintQty = 1
	PrintNo = 1
		For i = 1 To Count
				Call AddNote()
				oDoc.Activate
				With oPrintMgr
					.NumberOfCopies = 1
					.PaperSize = PaperSizeEnum.kPaperSizeLetter
					.SubmitPrint
					'MessageBox.Show(Arr(i), "Print A")
				End With
				Call DeleteNote()
			End If
		Next i
	End While
End Sub
Sub AddNote()
	Dim AddNoteinvApp As Inventor.Application
	AddNoteinvApp = ThisApplication
	Dim AddNoteoDrawDoc As Document
	AddNoteoDrawDoc = AddNoteinvApp.ActiveEditDocument
	Dim UserStr As String
	Dim dateStr As Date
	Dim PlotStamp As String
	dateStr = Now
	UserStr = ThisApplication.GeneralOptions.UserName
	PlotStamp = UserStr +"     "+dateStr
	Dim AddNoteoTG As Inventor.TransientGeometry = AddNoteinvApp.TransientGeometry
	For Each AddNoteoSheet In AddNoteoDrawDoc.Sheets
		AddNoteoNote = AddNoteoSheet.DrawingNotes.GeneralNotes.AddFitted(AddNoteoTG.CreatePoint2d(.5,4), PlotStamp)
		With AddNoteoNote
			.Rotation = (PI/2)+.001 'radianti
			.LineSpacing = .8125
			.VerticalJustification = Inventor.VerticalTextAlignmentEnum.kAlignTextMiddle
			.HorizontalJustification = Inventor.HorizontalTextAlignmentEnum.kAlignTextLeft
			.FormattedText = "<StyleOverride FontSize = '.25'>" & PlotStamp & "</StyleOverride>"
		End With
		AddNoteoDrawDoc.Update()
	Next
 End Sub
 Sub DeleteNote()
 	Dim DeleteNoteinvApp As Inventor.Application
	DeleteNoteinvApp = ThisApplication
	Dim DeleteNoteoDrawDoc As Document
	DeleteNoteoDrawDoc = DeleteNoteinvApp.ActiveEditDocument
	For Each oSheet In DeleteNoteoDrawDoc.Sheets
		For Each oGeneralNote In oSheet.DrawingNotes.GeneralNotes
			If oGeneralNote.Rotation = (PI/2)+.001
				oGeneralNote.Delete
			End If
		Next
	Next
 End Sub
Sub main()
	For i = 1 To Count
	Next i
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
	PrintQty = 1
	PrintNo = 1
		For i = 1 To Count
				Call AddNote()
				oDoc.Activate
				With oPrintMgr
					.NumberOfCopies = 1
					.SubmitPrint
				End With
				Call DeleteNote()
			End If
		Next i
	End While
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
	PrintQty = 3
	PrintNo = 1
		For i = 1 To Count
				Call AddNote()
				oDoc.Activate
				With oPrintMgr
					.NumberOfCopies = 1
					.SubmitPrint
				End With
				Call DeleteNote()
			End If
		Next i
	End While
	PrintQty = 1
	PrintNo = 1
		For i = 1 To Count
				Call AddNote()
				oDoc.Activate
				With oPrintMgr
					.NumberOfCopies = 1
					.SubmitPrint
				End With
				Call DeleteNote()
			End If
		Next i
	End While
End Sub
Sub AddNote()
	Dim dateStr As Date
	dateStr = Now
		With AddNoteoNote
		End With
	Next
 End Sub
 Sub DeleteNote()
				oGeneralNote.Delete
			End If
		Next
	Next
 End Sub
3 REPLIES 3
Sergio.D.Suárez
Hi, Actually, I did not understand the procedure well, but I modified its code a bit to eliminate some lines that seemed to me with errors. To begin instead of the order to open a hidden file in a hidden mode, I directly perform actions, add note, print, delete the note, and then I close it (without saving) and move on to the next one.
Making the same modification for the remaining visible files. I think it is important to activate and deactivate each work file properly so that the rule add note and delete note act on the active documents that correspond to them.
I hope it will be useful. regards
Sub Main()
	For i = 1 To Count
	Next i
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
	PrintQty = 1
	PrintNo = 1
		For i = 1 To Count
			oDoc = ThisApplication.Documents.VisibleDocuments.Item(i)
				oDoc.Activate
				Call AddNote()
				oPrintMgr = oDoc.PrintManager
				With oPrintMgr
					.NumberOfCopies = 1
					.SubmitPrint
				End With
				Call DeleteNote()
				oDoc.close
			End If
		Next i
	End While
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
	PrintQty = 3
	PrintNo = 1
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				With oPrintMgr
					.NumberOfCopies = 1
					.SubmitPrint
				End With
				Call DeleteNote()
				oDoc.close
			End If
		Next i
	End While
	PrintQty = 1
	PrintNo = 1
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				With oPrintMgr
					.NumberOfCopies = 1
					.SubmitPrint
				End With
				Call DeleteNote()
				oDoc.Close
			End If
		Next i
	End While
End Sub
Sub AddNote()
	Dim dateStr As Date
	dateStr = Now
		With AddNoteoNote
		End With
	Next
 End Sub
 Sub DeleteNote()
				oGeneralNote.Delete
			End If
		Next
	Next
 End Sub
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Sub Main()
	For i = 1 To Count
	Next i
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
	PrintQty = 1
	PrintNo = 1
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				With oPrintMgr
					.NumberOfCopies = 1
					.SubmitPrint
				End With
				Call DeleteNote()
				oDoc.close
			End If
		Next i
	End While
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
	PrintQty = 3
	PrintNo = 1
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				With oPrintMgr
					.NumberOfCopies = 1
					.SubmitPrint
				End With
				Call DeleteNote()
				oDoc.close
			End If
		Next i
	End While
	PrintQty = 1
	PrintNo = 1
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				With oPrintMgr
					.NumberOfCopies = 1
					.SubmitPrint
				End With
				Call DeleteNote()
				oDoc.Close
			End If
		Next i
	End While
End Sub
Sub AddNote()
	Dim dateStr As Date
	dateStr = Now
		With AddNoteoNote
		End With
	Next
 End Sub
 Sub DeleteNote()
				oGeneralNote.Delete
			End If
		Next
	Next
 End Sub
Mechanical Designer
ACritchelow
Thank you for reviewing my work. I used the open instead of visible because i had to sort the files by filename. I do not know how to read the visible.item() and set it to a veritable. After testing your modifications, the files were being printed in the order they were opened and not in the order of file name A to Z on one printer and Z to A on the other, So i returned to the open. One item that i was missing was the .close after each file in the loop. After adding this it looks as if it works like a charm. I did some cleanup in my code as well and this is what my final code looks like.
If you could tell me how to sort my files by name and get the files to come up in order A to Z using the .item() i would love to learn from your experience!!!
Sub Main()
	For i = 1 To Count
	Next i
	'Getting the sheets in the order they should be printed Z to A
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
	PrintQty = 1 '# of of prints required
	PrintNo = 1 '# being printed
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				Paper = PaperSizeEnum.kPaperSizeLetter
				Call Plot(oDoc, Paper)
				Call DeleteNote()
				oDoc.close
			End If
		Next i
	End While
	'Getting the sheets in the order they should be printed A to Z
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
	PrintQty = 3 '# of of prints required
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				Paper = PaperSizeEnum.kPaperSize11x17
				Call DeleteNote()
				oDoc.close
			End If
		Next i
	End While
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				Paper = PaperSizeEnum.kPaperSizeDSheet
				Call DeleteNote()
				oDoc.close
			End If
		Next i
	End While
End Sub
Sub AddNote() 'add plot stamp
	Dim dateStr As Date
	dateStr = Now
		With AddNoteoNote
			.FormattedText = "<StyleOverride FontSize = '.1875'>" & PlotStamp & "</StyleOverride>"
		End With
	Next
 End Sub
 Sub DeleteNote()  'remove plot stamp
				oGeneralNote.Delete
			End If
		Next
	Next
 End Sub
 Sub Plot(oDoc, Paper) 'runs the prints
	With oPrintMgr
		.NumberOfCopies = 1
		.PaperSize = Paper
		'.SubmitPrint
	End With
End Sub
Sub Main()
	For i = 1 To Count
	Next i
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				Call DeleteNote()
				oDoc.close
			End If
		Next i
	End While
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				Call DeleteNote()
				oDoc.close
			End If
		Next i
	End While
		For i = 1 To Count
				oDoc.Activate
				Call AddNote()
				Call DeleteNote()
				oDoc.close
			End If
		Next i
	End While
End Sub
	Dim dateStr As Date
	dateStr = Now
		With AddNoteoNote
		End With
	Next
 End Sub
				oGeneralNote.Delete
			End If
		Next
	Next
 End Sub
	With oPrintMgr
		.NumberOfCopies = 1
		.PaperSize = Paper
		'.SubmitPrint
	End With
End Sub
Sergio.D.Suárez
Hello, first of all, I am also an apprentice, I am like your researcher and the doubts that arise also I learn.
Try to make a code that alphabetically orders open documents and this small segment seems to work.
	Dim  AlphaOrder As New ArrayList
	For i = 1 To Count
		 AlphaOrder.Add(VisDocs.Item(i).displayname)
	Next i
	 AlphaOrder.Sort()
	For i = 0 To Count - 1
		MessageBox.Show(AlphaOrder(i))
	Next i
  I have not tested it in its entirety, I think it could be added to your code, maybe correcting it in this way.
I hope it works. I'm sure there will be simpler methods and maybe more practical, if I can find some I'll leave it here. regards
	For i = 1 To Count
	Next i
	 AlphaOrder.Sort()
	For i = 1 To Count
		Filename = AlphaOrder(i - 1)
		For j = 1 To Count
			If VisDocs.Item(j).Displayname = Filename Then
			    Arr(j) = VisDocs.Item(j).fullDocumentName
				Exit For
			End If
		Next j
	Next i
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
Mechanical Designer
	For i = 1 To Count
	Next i
	 AlphaOrder.Sort()
	Next i
	For i = 1 To Count
	Next i
	 AlphaOrder.Sort()
	For i = 1 To Count
		For j = 1 To Count
				Exit For
			End If
		Next j
	Next i
	            temp = Arr(j)
	            Arr(j) = Arr(i)
	            Arr(i) = temp
	        End If
	    Next j
	Next i
Mechanical Designer
