Autodesk Inventor 2024 taking old file reference for suppress parts.
pranaykapse1
pranaykapse1
I have an assembly(let's say "A") created using Skeleton (one part with multiple solid bodies in it, Assembly created using derived parts) modeling.
whenever I copy the design of this assembly(A), the suppressed parts take old file references only.
then I have to change the reference of suppressed parts manually every time for all suppressed parts of Assembly (B), which is too hectic for the user.
Then if I wanted to copy the design of Assembly B to Assembly C I could not possibly because Assembly B had old references in it, if I did not change the reference manually.
Please have a look into this issue.
Thanks & Regards
Pranay Kapse.
bradeneuropeArthur
This is one of the reasons I don't like the possibility to edit the Primairy/Master Model State:
https://forums.autodesk.com/t5/inventor-ideas/lock-the-quot-master-primary-quot-model-state/idi-p/12...
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
