I have found the Attribute Helper from Brian Ekins very helpuf and it has in fact became a must for the work I am doing preparing automated 2D drawings for my company. I have come to a small issue I would like to point out to take into consideration in later versions.
When working in 2D drawings I use attributes to identify some elements in the drawings, mainly DrawingDimensions.
If you assign to an element an AttributeSet, but you delete that element later, the set of attributes remains appearing as linked to an element called "Nothing". When you are working in a drawing for quite a long time you can get quite a lot of those "Nothing".
I can delete the attribute set on this entity and the entity "Nothing" will dissapear, but when I press OK to close the AttributeHelper, I get the following message:
"Unexpected failure while updating the attribute information."
After that error the entity keeps on appearing on the list, so the "Nothing"'s keep on accumulating.
I attach some screen shots in attached PDF file.
I am very happy with the tool, and really grateful for it being shared. I just want to help to improve it!
(If you also find the Attribute Helper a must, you can support the following idea in IdeaStation: integration-of-attribute-helper)
I am working with:
Autodesk Inventor Professional 2015
64-Bit Edition
Build:203
Release: 2015 SP1 Update 3
Hello Rodrigo.
I do Automated drawings and within the procedure of cleaning up the drawing prior to adding new dims which will have new attributes added i clean up the unused attributes with the attached rule.
This rule purges all the unused attributes, Hope it helps you out.
Regards
Paul
Private Sub PurgeAttributeSet() 'Removes/Deletes all unused Attributes Try Dim oApp = ThisApplication If oApp.ActiveDocument.DocumentType <> _ DocumentTypeEnum.kDrawingDocumentObject Then MsgBox("Need to have an Drawing document active") Exit Sub End If Dim oDrawDoc As DrawingDocument oDrawDoc = oApp.ActiveDocument Dim oAttbMan = oDrawDoc.AttributeManager oAttbMan.PurgeAttributeSets("*") Catch ex As Exception MsgBox(ex.ToString()) End Try End Sub
Thanks Paul. It works for me perfectly!.
It would be great if that could be added as a Purge button in the Attribute Helper.
