Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Add Part Title To Save Name Macro
7 REPLIES 7
Message 1 of 8
jkunLLJ2Y
455 Views, 7 Replies
jkunLLJ2Y
I have a working macro for saving a file, however I need to add the title of the part to the end of the file name, and I cannot find the code for it.
oDataMedium.FileName = "U:\DWF\" & onamefile & " " & TITLE & ".dwf"
7 REPLIES 7
Message 2 of 8
A.Acheson
in reply to: jkunLLJ2Y
A.Acheson
@jkunLLJ2Y
Are you using VBA or iLogic? This is a list for ilogic snippets.
https://adndevblog.typepad.com/manufacturing/2018/04/accessing-iproperties-through-ilogic-code.html
If I am correct you can not use ilogic snippets in VBA and need to use property sets. Perhaps you can verify if they work?
https://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Regards
Alan
@jkunLLJ2Y
Regards
Alan
Message 3 of 8
jkunLLJ2Y
in reply to: A.Acheson
jkunLLJ2Y
I am using VBA, and there is no "Title" code in the PropertySets that I could find.
Message 4 of 8
A.Acheson
A.Acheson
Here is a more up to date list and you can extract a list of your current inventor release.
https://modthemachine.typepad.com/my_weblog/iproperties/
Regards
Alan
Regards
Alan
Message 5 of 8
jkunLLJ2Y
jkunLLJ2Y
I tried that, the "Title / 2"
However it just spits out a 0
Message 6 of 8
A.Acheson
A.Acheson
@jkunLLJ2Y
Can you try the sample read iproperty sub in the image and change the property set and property as the per the chart referencing title. Failing that post the code your using to extract the title string from the file.
Regards
Alan
@jkunLLJ2Y
Regards
Alan
Message 7 of 8
jkunLLJ2Y
jkunLLJ2Y
I'm not sure exactly what you mean, but this is what I have now.
Message 8 of 8
jkunLLJ2Y
jkunLLJ2Y
I figured it out.
Dim oDoc As String
oDoc = ThisApplication.ActiveDocument.PropertySets.Item(1).Item(1).Value
Thanks for the help.
I figured it out.
Dim oDoc As String
