Add Part Title To Save Name Macro
jkunLLJ2Y
jkunLLJ2Y
I have a working macro for saving a file, however I need to add the title of the part to the end of the file name, and I cannot find the code for it.
oDataMedium.FileName = "U:\DWF\" & onamefile & " " & TITLE & ".dwf"
Replies (7)
A.Acheson
@jkunLLJ2Y
Are you using VBA or iLogic? This is a list for ilogic snippets.
https://adndevblog.typepad.com/manufacturing/2018/04/accessing-iproperties-through-ilogic-code.html
If I am correct you can not use ilogic snippets in VBA and need to use property sets. Perhaps you can verify if they work?
https://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Regards
Alan
jkunLLJ2Y
I am using VBA, and there is no "Title" code in the PropertySets that I could find.
A.Acheson
Here is a more up to date list and you can extract a list of your current inventor release.
https://modthemachine.typepad.com/my_weblog/iproperties/
Regards
Alan
jkunLLJ2Y
I tried that, the "Title / 2"
However it just spits out a 0
A.Acheson
@jkunLLJ2Y
Can you try the sample read iproperty sub in the image and change the property set and property as the per the chart referencing title. Failing that post the code your using to extract the title string from the file.
Regards
Alan
jkunLLJ2Y
I'm not sure exactly what you mean, but this is what I have now.
jkunLLJ2Y
I figured it out.
Dim oDoc As String
oDoc = ThisApplication.ActiveDocument.PropertySets.Item(1).Item(1).Value
Thanks for the help.
