Add Parameter to Assembly File (Remove _1, _2 extension one) and after that Coppy all parameter into all sub-assembly file
7 REPLIES 7
Message 1 of 8
tamnn.designer
346 Views, 7 Replies
Hi Bro.
I have code to add all parameter from code to assembly file. It worked. But if i run one more time. they are not stop but also add _1, _2 version => I would like to add some more line to stop if the parameter available already.
2. After created that parameter above to the assembly file => I would also coppy to all sub-assembly as the same name.
Could your please kindly help and support and improve.
Many thanks.
If ThisDoc.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	oMyParameter = ThisAssembly.Document.ComponentDefinition.Parameters.UserParameters
Else
	oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
End If
''THIS WORKS NOTE PARAMETERS WILL BE ADDED IN THE EXACT ORDER THEY ARE GENERATED IN THIS LIST
oParameter = oMyParameter.AddByExpression("extent_dim_X", "1", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter.ExposedAsProperty = True
oParameter = oMyParameter.AddByExpression("extent_dim_Y", "1", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter = oMyParameter.AddByExpression("extent_dim_T", "1", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter = oMyParameter.AddByExpression("part_area", "1", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter = oMyParameter.AddByExpression("bend_number", "1", UnitsTypeEnum.kUnitlessUnits)
oParameter = oMyParameter.AddByExpression("Xcubic", "1", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter = oMyParameter.AddByExpression("Ycubic", "1", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter = oMyParameter.AddByExpression("Zcubic", "1", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter = oMyParameter.AddByExpression("thread_hole_number", "1", UnitsTypeEnum.kUnitlessUnits)
'Next oParameter
'param.CustomPropertyFormat.Precision = kThreeDecimalPlacesPrecision
'param.CustomPropertyFormat.ShowTrailingZeros = True
'param.CustomPropertyFormat.ShowUnitsString = True
'param.CustomPropertyFormat.Units = "in"
iLogicVb.UpdateWhenDone = True
7 REPLIES 7
Message 2 of 8
Hi Bro,
Can i borrow somebody few mins. Many thanks.
Message 3 of 8
Here is my go at it, this code creates the said parameters in the assembly you are firing the rule from, then goes through each sub-assembly and also creates those same parameters. It also prevents parameters from duplicating :
Sub Main()
	Dim Doc As Inventor.AssemblyDocument = ThisApplication.ActiveDocument
	Dim AssyCompDef As Inventor.AssemblyComponentDefinition = Doc.ComponentDefinition
	Create_Params(Doc)
	For Each Occ As Inventor.ComponentOccurrence In AssyCompDef.Occurrences
		Dim RefDoc As Inventor.Document = Occ.ReferencedDocumentDescriptor.ReferencedDocument
		Create_Params(RefDoc)
	Next
End Sub
Private Sub Create_Params(doc As Inventor.Document)
	Dim CompDef As Inventor.ComponentDefinition = doc.ComponentDefinition
	Dim UserParams As Inventor.UserParameters = CompDef.Parameters.UserParameters
	Dim pNames As String() = {"extent_dim_X", "extent_dim_Y", "extent_dim_T", "part_area", "bend_number", "Xcubic", "Ycubic", "Zcubic", "thread_hole_number" }
	Dim pValues As String() = {"1", "1", "1", "1", "1", "1", "1", "1", "1" }
	Dim pUnits As Object() = {UnitsTypeEnum.kMillimeterLengthUnits, UnitsTypeEnum.kMillimeterLengthUnits, UnitsTypeEnum.kMillimeterLengthUnits, UnitsTypeEnum.kMillimeterLengthUnits, UnitsTypeEnum.kUnitlessUnits, UnitsTypeEnum.kMillimeterLengthUnits, UnitsTypeEnum.kMillimeterLengthUnits, UnitsTypeEnum.kMillimeterLengthUnits, UnitsTypeEnum.kUnitlessUnits }
	For i As Integer = 0 To pNames.Length - 1
		Dim check As Boolean = False
		For Each p As Inventor.Parameter In UserParams
			If p.Name = pNames(i) Then check = True
		Next
		If check = True Then Continue For
		Dim newParam As Inventor.Parameter = UserParams.AddByExpression(pNames(i), pValues(i), pUnits(i))
		newParam.ExposedAsProperty = True
	Next
End Sub
 Please mark this as solution if it helped out ! 😄
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 4 of 8
WCrihfield
in reply to: tamnn.designer
Hi @tamnn.designer.  Attached is a text file of another iLogic rule I had that you could try for this task.  I customized the parameter data to match the data you posted above.  And customized it to only work on referenced sub assemblies, at all levels.
Edit:  Oops, it does not do the 'Exposed as Property' and related settings part.  But that could easily be added into the Sub routine's code, in if needed.
Wesley Crihfield
(Not an Autodesk Employee)
Message 5 of 8
WCrihfield
This version is customized a bit further, to expose the parameter as a custom iProperty then set the options the way you have them in your first post.
Wesley Crihfield
Message 6 of 8
That's great to hear. Thank you very much!
Message 7 of 8
tamnn.designer
in reply to: WCrihfield
That's also perfect. Thank a lot
Message 8 of 8
Hi Sir,
i am doing the stupid way. I use 2 code.
Frist. Add all parameter from external rule into the main assembly and Sub-Assembly
Second: I copied all parameter from the current main assembly into all children part.
=> Parameter from Assemblies = Parts.  That is not good for me later. I would choose which parameter will add into Assemblies, and which parameters will go all children parts.
Finally: One code combination 2 step but choose the destination
 - I would want all parameter in this code input to all parts.
- Some parameter Xcubic, Ycubic and Zcubic input to main assembly and sub-assembly only "
Thank a lot and best regards
Sub Main
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
Dim oADoc As AssemblyDocument = ThisDoc.FactoryDocument
Dim oParamsData As New List(Of List(Of Object))
oParamsData.Add(New List(Of Object) From {"extent_dim_X", "1", UnitsTypeEnum.kMillimeterLengthUnits })
oParamsData.Add(New List(Of Object) From {"extent_dim_Y", "1", UnitsTypeEnum.kMillimeterLengthUnits })
oParamsData.Add(New List(Of Object) From {"extent_dim_T", "1", UnitsTypeEnum.kMillimeterLengthUnits })
oParamsData.Add(New List(Of Object) From {"part_area", "1", UnitsTypeEnum.kMillimeterLengthUnits })
oParamsData.Add(New List(Of Object) From {"bend_number", "1", UnitsTypeEnum.kUnitlessUnits })
oParamsData.Add(New List(Of Object) From {"Xcubic", "1", UnitsTypeEnum.kMillimeterLengthUnits })
oParamsData.Add(New List(Of Object) From {"Ycubic", "1", UnitsTypeEnum.kMillimeterLengthUnits })
oParamsData.Add(New List(Of Object) From {"Zcubic", "1", UnitsTypeEnum.kMillimeterLengthUnits })
oParamsData.Add(New List(Of Object) From {"thread_hole_number", "1", UnitsTypeEnum.kUnitlessUnits })
EnsureParamsExist(oADoc, oParamsData)
Dim oAllSubAsms As List(Of Inventor.Document) = oADoc.AllReferencedDocuments.OfType(Of Inventor.Document).Where(Function(d) d.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject).ToList
If oAllSubAsms Is Nothing OrElse oAllSubAsms.Count = 0 Then Exit Sub
For Each oSubAsm In oAllSubAsms
EnsureParamsExist(oSubAsm, oParamsData)
Next
If oADoc.RequiresUpdate Then oADoc.Update2(True)
End Sub
Sub EnsureParamsExist(oDoc As Document, oParamsData As List(Of List(Of Object)))
If oDoc Is Nothing Or (oParamsData Is Nothing OrElse oParamsData.Count = 0) Then Exit Sub
If oDoc.IsModifiable = False Then Exit Sub
Dim oUParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
For Each MainEntry In oParamsData
If MainEntry.Count = 0 Then Continue For
Dim oUParam As UserParameter = Nothing
Try
oUParam = oUParams.Item(MainEntry.First)
Catch
oUParam = oUParams.AddByExpression(MainEntry.First, MainEntry.Item(1), MainEntry.Last)
End Try
Try
If Not oUParam.ExposedAsProperty Then oUParam.ExposedAsProperty = True
Dim oCPF As CustomPropertyFormat = oUParam.CustomPropertyFormat
oCPF.Units = oDoc.UnitsOfMeasure.GetStringFromType(MainEntry.Last)
oCPF.Precision = CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision
oCPF.ShowLeadingZeros = True
oCPF.ShowTrailingZeros = True
Catch
End Try
Next
End Sub
Technology Administrators
