Add linear dimension by 2 point 2D inventor vba
Hello Everyone,
in the drawing, I would like to create a linear dimension by 2 2d points, how can I archive it? Please help me with this case.
bradeneuropeArthur
Sub main()
    ' Open a drawing document and select two parallel linear curves in same drawing view first.
    Dim oApp As Inventor.Application
    set oApp = ThisApplication
    Dim oDoc As Document
    set oDoc = oApp.ActiveDocument
    If Not (oDoc Is Nothing) Then
        If Not (oDoc.DocumentType = kDrawingDocumentObject) Then
            MsgBox "Please activate a drawing document for this sample.", vbCritical, "Inventor"
            Exit Sub
    Else
        MsgBox "Please open a drawing document for this sample.", vbCritical, "Inventor"
        Exit Sub
    If Not (oDoc.SelectSet.Count = 2) Then
        MsgBox "Please select two parallel linear drawing curves from same drawing view for this sample.", vbCritical, "Inventor"
        Exit Sub
    ElseIf (oDoc.SelectSet(1).Type <> kDrawingCurveSegmentObject Or oDoc.SelectSet(1).Type <> kDrawingCurveSegmentObject) Then
        Exit Sub
    Dim oCurve1 As DrawingCurve, oCurve2 As DrawingCurve
    set oCurve1 = oDoc.SelectSet(1).Parent
    set oCurve2 = oDoc.SelectSet(2).Parent
    Dim oSheet As Sheet
    set oSheet = oCurve1.Parent.Parent
    ' Create two GeometryIntent based on the selected drawing curve segments.
    Dim oIntent1 As GeometryIntent, oIntent2 As GeometryIntent
    set oIntent1 = oSheet.CreateGeometryIntent(oCurve1)
    set oIntent2 = oSheet.CreateGeometryIntent(oCurve2)
    Dim oTextPos As Point2d
    set oTextPos = oApp.TransientGeometry.CreatePoint2d(12, 12)
    ' Create the linear foreshortened dimension
    Dim oLinearForeshortenedDim As LinearGeneralDimension
    'oLinearForeshortenedDim = oSheet.DrawingDimensions.GeneralDimensions.AddLinearForeshortened(oTextPos, oIntent1, oIntent2, True)
    oLinearForeshortenedDim = oSheet.DrawingDimensions.GeneralDimensions.AddLinear(oTextPos, oIntent1, oIntent2)
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
agrove72Y9W
You can create a geometry intent at the intersection between two drawing curves
Dim oSheet As Sheet = ThisDoc.Document.Sheets.Item(1)
Dim oCurve1, oCurve2 As DrawingCurve
[insert code for specifying oCurve1 and oCurve2]
Dim oIntent As GeometryIntent = oSheet
.CreateGeometryIntent(oCurve1, oCurve2)
