Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Add LeaderNote to Dimension using the API
6 REPLIES 6
AlexFielder
591 Views, 6 Replies
Hi all,
This is a problem I just came upon whilst working on a customer addin. Using c# I am attempting to add a leader note like this:
The part I am struggling with is accessing the start/end of the dimension line I wish to attach to.
Here is the code I have for this and the line that errors is in red:
private static void AddUniqueHoleCountsToDrawingView(Sheet drawingSheet, DrawingView baseView)
            LeaderNotes leaderNotes = drawingSheet.DrawingNotes.LeaderNotes;
            double initialSpacing = 2;
            double spacingLeft = 1;
            double spacingRight = spacingLeft;
            foreach (LinearGeneralDimension item in UniqueYDimensions)
                ObjectCollection leaderPoints = ThisApplication.TransientObjects.CreateObjectCollection();
                Line2d dimLine = item.DimensionLine;
                double[] startPoint = new double[2];
                double[] endPoint = new double[2];
                dimLine.Evaluator.GetEndPoints(ref startPoint, ref endPoint);
                Point2d dimLineStart = TransGeom.CreatePoint2d(startPoint[0], startPoint[1]);
                Point2d dimLineEnd = TransGeom.CreatePoint2d(endPoint[0], endPoint[1]);
                Point2d leaderNoteElbow = null;
                Point2d leaderNotePosn = null;
                if (dimLineStart.Y < dimLineEnd.Y) //left?
                    if (spacingLeft == 1)
                        leaderNoteElbow = TransGeom.CreatePoint2d(dimLineStart.Y - initialSpacing, dimLineStart.X);
                        leaderNotePosn = TransGeom.CreatePoint2d(leaderNoteElbow.Y, leaderNoteElbow.X + 2);
                    else
                        leaderNoteElbow = TransGeom.CreatePoint2d(dimLineStart.Y - initialSpacing - spacingLeft, dimLineStart.X);
                        spacingLeft++;
                    leaderPoints.Add(dimLineStart);
                    leaderPoints.Add(leaderNoteElbow);
                    leaderPoints.Add(leaderNotePosn);
                else
                    if (spacingRight == 1)
                        leaderNoteElbow = TransGeom.CreatePoint2d(dimLineEnd.Y - initialSpacing, dimLineEnd.X);
                        leaderNotePosn = TransGeom.CreatePoint2d(leaderNoteElbow.Y, leaderNoteElbow.X - 2);
                    else
                        leaderNoteElbow = TransGeom.CreatePoint2d(dimLineEnd.Y - initialSpacing - spacingRight, dimLineEnd.X);
                        spacingRight++;
                    leaderPoints.Add(dimLineEnd);
                LeaderNote newLeader = leaderNotes.Add(leaderPoints, "# Unique Holes");
There don't seem to be ANY other posts that deal with dimensions in this way that I can find, so perhaps someone from Autodesk can help?
Alex.
6 REPLIES 6
JaneFan
in reply to: AlexFielder
Hello Alex,
Please try to change Line2d to LineSegment.
Jane Fan
Inventor QA Engineer
AlexFielder
in reply to: JaneFan
Hi @JaneFan
Changing the type to LineSegment didn't work, but changing it to dynamic does.
My next question is this; the leaders get placed, but two things are wrong with my code above:
  1. The leader isn't attached to the geometry so when the view moves, the leadernotes do not.
  2. The text that gets placed ends up at the same position as the arrow point, not as intended below the dimension (as per my screenshot above)
My guess is 1) needs a GeometryIntent.
As for 2) I'm not 100% sure the points are in the correct position, but is there something else I'm missing?
Alex.
AlexFielder
So here's where I am at:
            try
                GeneralDimensions genDims = drawingSheet.DrawingDimensions.GeneralDimensions;
                double spacingLeft = 0;
                double spacingRight = 0;
                    ObjectCollection leaderPoints = RadialHoles.m_InventorApp.TransientObjects.CreateObjectCollection();
                    dynamic dimLine = item.DimensionLine;
                    Point2d dimLineStart = (Point2d)dimLine.StartPoint;
                    Point2d dimLineEnd = (Point2d)dimLine.EndPoint;
                    GeometryIntent leaderIntent = null;
                    Point2d viewCentre = baseView.Center;
                    if (dimLineStart.X < viewCentre.X)
                        if (spacingLeft == 0)
                            leaderNoteElbow = TransGeom.CreatePoint2d(dimLineStart.X, dimLineStart.Y - initialSpacing);
                            leaderNotePosn = TransGeom.CreatePoint2d(leaderNoteElbow.X + 2, leaderNoteElbow.Y);
                            spacingLeft += 1;
                        else
                            leaderNoteElbow = TransGeom.CreatePoint2d(dimLineStart.X, dimLineStart.Y - initialSpacing - spacingLeft);
                            spacingLeft += 1;
                        leaderIntent = drawingSheet.CreateGeometryIntent(item, dimLineStart);
                        leaderPoints.Add(leaderIntent);
                    else
                        if (spacingRight == 0)
                            leaderNotePosn = TransGeom.CreatePoint2d(leaderNoteElbow.X - 2, leaderNoteElbow.Y);
                            spacingRight += 1;
                        else
                            leaderNoteElbow = TransGeom.CreatePoint2d(dimLineStart.X, dimLineStart.Y - initialSpacing - spacingRight);
                            spacingRight += 1;
                    AttributeSet dimAttSet = item.AttributeSets[1];
                    Inventor.Attribute numHoles = dimAttSet["UniqueHoleCount"];
                    Inventor.Attribute holeSize = dimAttSet["UniqueHoleSize"];
                    LeaderNote newLeader = leaderNotes.Add(leaderPoints, numHoles.Value + " HOLES ");
            catch (Exception ex)
                log.Error(ex.Message, ex);
This is mostly working, my next question is how can I place the diameter symbol using the API in the line highlighted in Red above?
Alex.
JaneFan
Hello Alex,
For 1) Yes, GeometryIntent is needed.
For 2) There should be a setting for LeaderStyle like DimensionTextOrientation in API, as that of in UI. But I didn't find the correct property, will consult with the relative engineers and get back to you later.
Jane Fan
JaneFan
Hi @AlexFielder
Sorry that API doesn't support setting the leader text orientation for now as UI does.
Jane Fan
AlexFielder
Hi @JaneFan,
Thanks for looking this up for me; the text alignment is (for my needs) taken care of by the direction of the nearest nodes in the LeaderNote.
As far as the solution is concerned, this is what I ended up with:
            try
                            spacingLeft += 1;
                        else
                            spacingLeft += 1;
                    else
                            spacingRight += 1;
                        else
                            spacingRight += 1;
                    //AttributeSet dimAttSet = ;
                    LeaderNote newLeader = leaderNotes.Add(leaderPoints, numHoles.Value + " HOLES Ø" + holeSize.Value);
Thanks again,
Alex.
