Add-In missing from Add-In Manager
CGVJM6DF
Message 1 of 9
CGVJM6DF
HI
I tray to do an Add-In in VS 2022 for Inventor 2024.2 "Following" this tutorial: https://www.youtube.com/watch?v=QROrJdg0NQ8
All it is good but whatever I do I can't see the Add-In in to the Add-In Manager...
I did it befor for Inventor 2022 following the same tutorial and it wase ok but now....
Can somebody help me?
Replies (8)
Message 2 of 9
Frederick_Law
Not gonna watch the video 😜
Addin folder and file should be in %appdata%\Autodesk\ApplicationPlugins
It'll need the .dll and .addin files.
<Addin Type="Standard">
  <!--Created for Autodesk Inventor Version 21.0-->
  <ClassId>{addin class ID}</ClassId>
  <ClientId>{addin class ID}</ClientId>
  <DisplayName>AssemCount</DisplayName>
  <Description>AssemCount</Description>
  <Assembly>AssemCount.dll</Assembly>
  <LoadOnStartUp>1</LoadOnStartUp>
  <LoadAutomatically>1</LoadAutomatically>
  <!--LoadBehavior  0:Start with Inventor -->
  <!--LoadBehavior  1:Start with part -->
  <!--LoadBehavior  2:Start with assembly -->
  <!--LoadBehavior  3:Start with presentation -->
  <!--LoadBehavior  4:Start with drawing -->
  <!--LoadBehavior 10:On Demand -->
  <LoadBehavior>2</LoadBehavior>
  <UserUnloadable>1</UserUnloadable>
  <Hidden>0</Hidden>
  <SupportedSoftwareVersionGreaterThan>21.0</SupportedSoftwareVersionGreaterThan>
  <DataVersion>1</DataVersion>
  <UserInterfaceVersion>1</UserInterfaceVersion>
</Addin>
Message 3 of 9
CGVJM6DF
Tanks @Frederick_Law
Nothing...😔
Message 4 of 9
Frederick_Law
What do you mean by "nothing"?
What did you check or try?
You can't find the folder?
You can't find the files?
Message 5 of 9
JelteDeJong
Sometime ago I wrote a tutorial about creating an addin. Maybe the part "Help: My addin won't load" is some help to you.
Jelte de Jong
Blog: hjalte.nl - github.com
Message 6 of 9
CGVJM6DF
HI @JelteDeJong
I have try your example too, but nothing works! I can't see them in Add-In Manager
Message 7 of 9
JelteDeJong
You should have created an *.addin file. And have saved it on 1 of the locations I wrote about. Can you share that file?
Jelte de Jong
Message 8 of 9
CGVJM6DF
Do you mean this file:
Unfortunately I am not allowed to drag the file here....
This is what it is in this file.
Message 9 of 9
JelteDeJong
I'm not familiar with this way of viewing XML files. (I like to open them with notepad) Anyway, I see potential problems.
  • The dll name is surrounded by square brackets. They should not be there.
  • If I'm correct your <SupportedSoftwareVersionGreaterThan> is for Inventor 2023. I don't know which version you are working with but I would set it to 16 (Inventor 2015) for debugging purposes. Just to be sure that is not the problem.
Jelte de Jong
