Add-In missing from Add-In Manager
CGVJM6DF
CGVJM6DF
HI
I tray to do an Add-In in VS 2022 for Inventor 2024.2 "Following" this tutorial: https://www.youtube.com/watch?v=QROrJdg0NQ8
All it is good but whatever I do I can't see the Add-In in to the Add-In Manager...
I did it befor for Inventor 2022 following the same tutorial and it wase ok but now....
Can somebody help me?
Replies (8)
Frederick_Law
Not gonna watch the video :winking_face_with_tongue:
Addin folder and file should be in %appdata%\Autodesk\ApplicationPlugins
It'll need the .dll and .addin files.
<Addin Type="Standard">
  <!--Created for Autodesk Inventor Version 21.0-->
  <ClassId>{addin class ID}</ClassId>
  <ClientId>{addin class ID}</ClientId>
  <DisplayName>AssemCount</DisplayName>
  <Description>AssemCount</Description>
  <Assembly>AssemCount.dll</Assembly>
  <LoadOnStartUp>1</LoadOnStartUp>
  <LoadAutomatically>1</LoadAutomatically>
  <!--LoadBehavior  0:Start with Inventor -->
  <!--LoadBehavior  1:Start with part -->
  <!--LoadBehavior  2:Start with assembly -->
  <!--LoadBehavior  3:Start with presentation -->
  <!--LoadBehavior  4:Start with drawing -->
  <!--LoadBehavior 10:On Demand -->
  <LoadBehavior>2</LoadBehavior>
  <UserUnloadable>1</UserUnloadable>
  <Hidden>0</Hidden>
  <SupportedSoftwareVersionGreaterThan>21.0</SupportedSoftwareVersionGreaterThan>
  <DataVersion>1</DataVersion>
  <UserInterfaceVersion>1</UserInterfaceVersion>
</Addin>
CGVJM6DF
Tanks @Frederick_Law
Nothing...:pensive_face:
Frederick_Law
What do you mean by "nothing"?
What did you check or try?
You can't find the folder?
You can't find the files?
JelteDeJong
Sometime ago I wrote a tutorial about creating an addin. Maybe the part "Help: My addin won't load" is some help to you.
Jelte de Jong
Blog: hjalte.nl - github.com
CGVJM6DF
HI @JelteDeJong
I have try your example too, but nothing works! I can't see them in Add-In Manager
JelteDeJong
You should have created an *.addin file. And have saved it on 1 of the locations I wrote about. Can you share that file?
Jelte de Jong
CGVJM6DF
Do you mean this file:
Unfortunately I am not allowed to drag the file here....
This is what it is in this file.
JelteDeJong
I'm not familiar with this way of viewing XML files. (I like to open them with notepad) Anyway, I see potential problems.
  • The dll name is surrounded by square brackets. They should not be there.
  • If I'm correct your <SupportedSoftwareVersionGreaterThan> is for Inventor 2023. I don't know which version you are working with but I would set it to 16 (Inventor 2015) for debugging purposes. Just to be sure that is not the problem.
Jelte de Jong
