Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Zoom Highlightset
Zoom Highlightset
Zoom Highlightset
Hi there,
I highlighted some drawingcurves in a drawing by the API and now I would like to "zoom fit" the highlighted set for a better visual effect. Does anyone known a solution?
greetings Joris
AI 2010, Win 7 64bit
jdkriek
This should work as long as the highlighted set counts as a selection or can be added to the selection set at least.
I formatted it for iLogic, but it's easy to tweak for VBA if needed.
Dim oDoc As AssemblyDocument: oDoc = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition: oDef = oDoc.ComponentDefinition
Dim oOccs As ComponentOccurrences: oOccs = oDef.Occurrences
Dim oOcc As ComponentOccurrence: oOcc = oOccs.Item(oOccs.Count)
Dim oSSet As SelectSet: oSSet = oDoc.SelectSet
Call oSSet.Select(oOcc)
Dim oControlDef As ControlDefinition: oControlDef = ThisApplication _
.CommandManager.ControlDefinitions _
.Item("AppZoomSelectCmd")
oControlDef.Execute
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Unfortunately, I think 'Zoom Selected' only works in the assembly environment and not in the drawing environment.
And when I execute a Control Definition I loose my highlighted set.
greetings Joris
jdkriek
Doh, it was late and I missed the part where this was a drawing. I'll tweak it tonight. Got to stop writing code so late 😉
Jonathan D. Kriek
ajcampbell
Was there a solution to this? I'm looking to do something similar from a .Net addin.
ajcampbell
