how to change the partlist insert point. Upper right point is sucks :-(
Message 1 of 8
When i insert a partlist in a drawing the insert point of the partlist is in the upper right corner? i want the insertpoint in the lower right corner, because i know the height of our titleblock. Then i will allways be able to possition the partlist right above the titleblock. I never know how heigh the partlist is because the amount of parts in the partlist is different every time. does anyone know if its possible to change the partlist insertpoint to the lower right corner of the partlist when its inserted via the API?
Help please.
Replies (7)
Message 2 of 8
jdkriek
This will put the Parts List right on top of your title block
Dim oDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Sheet =  oDoc.ActiveSheet
Dim oBorder As Border = oSheet.Border
Dim oPlacementPoint As Point2d
oModelDoc = ThisDrawing.ModelDocument
If Not oBorder Is Nothing Then
	oPlacementPoint = oBorder.RangeBox.MaxPoint
Else
	oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.Height)
For i = 1 To oSheet.PartsLists.Count
	oSheet.PartsLists.Item(1).Delete
Next i
Dim oPartsList As PartsList
oPartsList = oSheet.PartsLists.Add(oModelDoc, oPlacementPoint)
minXpoint = oSheet.TitleBlock.RangeBox.MinPoint.x
minYpoint = oSheet.TitleBlock.RangeBox.MaxPoint.Y
maxXpoint = oPlacementPoint.x
dPointY = oSheet.PartsLists.Item(1).RangeBox.MinPoint.Y - minYpoint
maxYpoint = oPlacementPoint.Y - dPointY
Dim newmin, newmax As Point2d
newmin = ThisApplication.TransientGeometry.CreatePoint2d(minXpoint, minYpoint)
newmax = ThisApplication.TransientGeometry.CreatePoint2d(maxXpoint, maxYpoint)
oPartsList = oSheet.PartsLists.Add(oModelDoc, newmax)
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 3 of 8
Thanks for this fine / great code example, you saved my day. If you ever come to denmark i will buy you a beer 🙂
i had to modify you code a bit but now it work right like i want i to. Again Thanks!
Here is what i ended up with i had to add the height of my titleblock.
regards Kent boettger
 Dim oDrawingView As DrawingView
        oDrawingView = oSheet.DrawingViews(1)
        Dim oPlacementpoint As Point2d
            oPlacementpoint = oBorder.RangeBox.MaxPoint
        Else
            oPlacementpoint = oApp.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.Height)
        'Delete old partlist if found
            oSheet.PartsLists.Item(1).Delete()
        Next
        'add new partlist and calculate placement
        oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementpoint)
        Dim minXpoint As Double = oSheet.TitleBlock.RangeBox.MinPoint.X
        Dim minYPoint As Double = oSheet.TitleBlock.RangeBox.MinPoint.Y
        Dim maxXPoint As Double = oPlacementpoint.X
        Dim dPointY As Double = oSheet.PartsLists.Item(1).RangeBox.MinPoint.Y - minYPoint
        Dim maxYpoint As Double = (oPlacementpoint.Y + 6.3#) - dPointY
        newmin = oApp.TransientGeometry.CreatePoint2d(minXpoint, minYPoint)
        newmax = oApp.TransientGeometry.CreatePoint2d(maxXPoint, maxYpoint)
        'Delete the inserted partlist again
        'Add final partlist.
        oPartsList = oSheet.PartsLists.Add(oDrawingView, newmax)
Message 4 of 8
jdkriek
Glad that worked for you.
Jonathan D. Kriek
Message 5 of 8
GosponZ
on default border working perfect, but on custom border i got error
Error on Line 3 : Type 'p534g9_0' is not defined.
 Jonathan can you help?
Thank you
Message 6 of 8
jdkriek
Thank you
MisterZS, I tested with a custom border and it works fine on my end. oSheet.Border contains whatever the active border is custom or not on the sheet. The only thing you could perhaps try is setting the active border before you define oBorder. But that was not needed to work for my tests.
ActiveSheet.Border = "YourCustomBorderName"
Jonathan D. Kriek
Message 7 of 8
GosponZ
I added line of code you suggest but still same error
Error on Line 5 : Type 'p534g9_0' is not defined.
but if i turn off line of code
'Dim oBorder As Border = oSheet.Border it is working but table stick to the sheet size not to the border.
Thank you
Message 8 of 8
GosponZ
I think i found problem. Word Border was in blue and that bother me somehow. I switched to lower case and bingo.
I don't know why.
Dim oBorder As border = oSheet.Border
But here is another question since code working perfect on my machine.
I'm working with multi sheets, and every sheet is with different part. I would like to insert part list table in each sheet  with iproperties for that part. I tried with this one and it is always same table in each sheet.
Is this possible?
Thank you
