Write to embedded text file in IDW?
DRoam
Mentor Mentor
Message 1 of 8
DRoam
I'd like to have my add-in write the actions that it performs on a Drawing file to a log file stored within the drawing itself. I'm having a hard time figuring out how to do so.
If found this: Mfg DevBlog: Read / Write embedded file, but it seems overly complicated. I'm hoping someone knows of a simpler way?
I need the add-in to create the log file as well as write (append) to it.
Replies (7)
Message 2 of 8
bradeneuropeArthur
What kind of information would you like to write the text file?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
bradeneuropeArthur
With this piece of code you can create the txt file and add it to the drawing...
Public Sub AttchAddToDwg()
Dim oDrawingDwgdoc As DrawingDocument
Set oDrawingDwgdoc = ThisApplication.ActiveDocument
Dim InvFilelocation As String
InvFilelocation = oDrawingDwgdoc.FullFileName
Dim InvFileName As String
InvFileName = oDrawingDwgdoc.DisplayName
                    Dim CompleteSendPathPartlistXls As String
                    CompleteSendPathPartlistXls = "File path and .txt"
    ' Referenceto a Other to be linked document.
    Dim objDocument As DrawingDocument
    Set objDocument = ThisApplication.ActiveDocument
    Dim objReferenceOLE As ReferencedOLEFileDescriptor
                'Set objReferenceOLE = objDocument.ReferencedOLEFileDescriptors.Add(CompleteSendpathPdf)
                Set objReferenceOLE = objDocument.ReferencedOLEFileDescriptors.Add(CompleteSendPathPartlistXls)
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 8
DRoam
Just the things my add-in is doing as it processes things about the drawing. Things like:
Filled in "Drawing #" iProperty for "Part X.ipt"
Filled in "Title" prompted entry in Title Block on Sheet 2
Toggled visibility of (3) rows in Parts List on Sheet 2.
The purpose is mainly for verification and tracking. The designer can look back through the log to see what the add-in changed and when, relative to each time the drawing has been printed.
Your code is a good start. Is there any way to read the embedded file? Perhaps by saving it back as a text file again first?
I don't want to create a new log file every time the update command runs. I want to either append to the existing file, or copy it, append the new log lines, then delete the original and re-save.
Message 5 of 8
DRoam
Actually, I think I came up with a simpler way to do this. I think what I may do is just store the log in a String attribute of the drawing document object. Then I'll just make a simple Windows Form to display the log in a text field, and add a command to display the form. This will be cleaner than adding the embedded file anyway.
Message 6 of 8
JelteDeJong
You could also save the text in a attribute of the file. here an example (in a ilogic rule)
Public Class ThisRule
	Private Log As String
	Private doc As Document
	Sub Main()
		loadLog()
		writeToLog("Test 1")
		writeToLog("Test 2")
		writeLogToFile("c:\temp\log.txt")
	End Sub
	Private Sub writeToLog(text As String)
		Log = Log + text + System.Environment.NewLine
		saveLog()
	End Sub
	Private Sub loadLog()
		If (doc.AttributeSets.NameIsUsed("log")) Then
			Dim attSet As AttributeSet = doc.AttributeSets.Item("log")
			Dim attLines As Attribute = attSet.Item("Lines")
			Log = attLines.Value
		Else
			Log = ""
	End Sub
	Private Sub saveLog()
			attLines.Value = Log
		Else
			Dim attSet As AttributeSet = doc.AttributeSets.Add("log")
			Dim attLines As Attribute = attSet.Add("Lines", ValueTypeEnum.kStringType, Log)
	End Sub
	Private Sub writeLogToFile(path As String)
		System.IO.File.AppendAllText(path, Log)
	End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
Message 7 of 8
DRoam
Lol, talk about timing. At the very least you saved me some time working out the details. Thanks @JelteDeJong, will mark your answer as the solution.
Message 8 of 8
JelteDeJong
Great minds think alike, and as it turns out in the same minute
Jelte de Jong
