WPF Window inside an Inventor Add-In
AlexFielder
Advisor Advisor
Message 1 of 17
AlexFielder
Hi all,
This post relates to this post by @adam.nagy so hopefully he will see and reply directly but:
I am attempting to create a wpf window inside of an Inventor Addin- I know I can do this with a windows form, but I found Adam's post and thought I would give it a try.
Inside of the Addin I added a User Control and placed the following code inside:
<Window x:Class="Power_Pack_For_Inventor_AddIn.SelectFeaturesWindow"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             xmlns:local="clr-namespace:Power_Pack_For_Inventor_AddIn"
             mc:Ignorable="d" ResizeMode="CanResize" Height="354.667" Width="457.333" BorderThickness="2" SizeToContent="WidthAndHeight" Padding="0">
    <StackPanel Background="Gray" Margin="0,0,0,0">
        <Button x:Name="button" Content="Button" VerticalAlignment="Bottom" Margin="0,0,0,0"/>
        <Border BorderBrush="OldLace" BorderThickness="10" CornerRadius="10"
            HorizontalAlignment="Center" VerticalAlignment="Center">
            <Image Source="ksp.jpg" Width="200" Height="200"
             Stretch="Fill" x:Name="blogImage" />
            <Border.RenderTransform>
                <SkewTransform CenterX="250" CenterY="0"
                       AngleX="0" AngleY="350" />
            </Border.RenderTransform>
        </Border>
        <Border Width="220" Height="300" BorderThickness="10"
            CornerRadius="10" BorderBrush="OldLace">
            <Border.Background>
                <VisualBrush Visual="{Binding ElementName=blogImage}">
                    <VisualBrush.Transform>
                        <ScaleTransform ScaleX="1" ScaleY="-1"
                            CenterX="200" CenterY="150" />
                    </VisualBrush.Transform>
                </VisualBrush>
            </Border.Background>
            <Border.OpacityMask>
                <LinearGradientBrush StartPoint="0,0" EndPoint="0,1">
                    <GradientStop Offset="0" Color="Black" />
                    <GradientStop Offset="0.3" Color="Transparent" />
                </LinearGradientBrush>
            </Border.OpacityMask>
                <SkewTransform CenterX="260" CenterY="0"
                       AngleX="40" AngleY="350" />
        </Border>
    </StackPanel>
</Window>
Inserted into the SelectFeaturesWindow.xaml.vb element of that Window.xaml file I have:
Namespace Power_Pack_For_Inventor_AddIn
    Partial Public Class SelectFeaturesWindow
        Inherits Window
        Public Sub New()
            'InitializeComponent()
        End Sub
        Private Sub button_Click(sender As Object, e As RoutedEventArgs) Handles button.Click
            MessageBox.Show("Hello World!", "Feature type selection.")
            Me.Close()
        End Sub
    End Class
End Namespace
Inside of my Inventor Addin I have a button which when clicked runs this code:
Try
	Dim oDoc As Document = g_inventorApplication.ActiveDocument
	'Show the WPF Form!
	Dim selectFeaturesFrm As New SelectFeaturesWindow
	Dim helper As New WindowInteropHelper(selectFeaturesFrm)
	helper.Owner = New IntPtr(g_inventorApplication.MainFrameHWND)
	selectFeaturesFrm.ShowDialog()
Catch ex As Exception
End Try
and all looks fine. The code builds, the addin loads and I can click the button in my ribbonbar.
The problem is that when the Window loads it looks like this inside of Inventor:
A big ol' screen of white nothing.
If I look in the designer inside of Visual Studio I can clearly see it working though:
EDIT: As I typed this out, I changed one thing and it started working:
I changed the uncommented the InitializeComponent() having previously modified the class inside of the XAML from this:
<Window x:Class="SelectFeaturesWindow"
To this:
And lo and behold it started working.
I could have not bothered with this post at all now that it is working but I figured it may help others like myself who are just starting
to delve into WPF with Inventor to pay attention to these small details.
Replies (16)
Message 2 of 17
adam.nagy
Autodesk Support
Autodesk Support
Hi Alex,
Glad you managed to figure it out and thanks for sharing it. 🙂
Since questions cannot be marked as solutions I'll mark my answer as such - so that others know it's solved.
Cheers,
Adam Nagy
Autodesk Platform Services
Message 3 of 17
dba78
Hi, just to clarify what happened:
in a Visual Basic-Project you don't need to add Namespace to each class you create. the compiler will add the Default Namespace of you project.
So you had your Default-Namespace
in you project and you additionally added it to your xam.vb
so after compile your partial class' (xaml.vb) qualified name became
Power_Pack_For_Inventor_AddIn.Power_Pack_For_Inventor_AddIn.SelectFeaturesWindow
your Xaml was compiled to
They "didn't find each other" on runtime....
So yes, adding this extra Namespace to your xaml-Class Name solved the problem apparently,
but you capsulated both in a subnamespace (xaml and xaml.vb)
The correct solution in this case is to remove the extra Namespace in xaml.vb
And finally: this is not related to Inventor, but to VB (In C# you are forced to fully qualify all your classes, so this wouldn't have popped up)
In WPF do not comment out the InitializeComponent() Method!!! In VB you're not forced to have the default ctor, but if you have it, the InitializeComponent calls the building of the UIElement and therefore must not be commented out!
Cheers,
Daniel
Message 4 of 17
Hi @adam.nagy,
I am using the same approach you mentioned in your article your https://adndevblog.typepad.com/manufacturing/2015/11/wpf-window-inside-an-inventor-add-in.html
but Addin(c#) doesn't show the images(.png and .jpg) dockable windows. I found some information about build event changing to resource in properties of images(https://stackoverflow.com/questions/15653105/in-my-wpf-application-my-loaded-png-logo-in-image-shows...).Could you pls help me with this?
Message 5 of 17
dba78
you may try the following:
  • add your image files as project resources (project-> properties->resources->images)
  • make sure the files will compiled as resources (select file in project explorer, 'F4' ->Build Action=Resource)
  • set 'Copy Local'=false
This way WPF finds the resource on runtime.
Message 6 of 17
Thanks for your reply. I have already tried these steps you mentioned.It is now working.
Message 7 of 17
dba78
could you please paste your call to the resource in XAML?
<Image Source="..."/>
Message 8 of 17
xaml.PNGstill can't see images. I debugging addin and compile. But the result is the same.
Message 9 of 17
dba78
hi, as assumed, you have a malformed Uri in your Source-Attribute.
this should help you out:
https://stackoverflow.com/questions/5552618/how-to-reference-image-resources-in-xaml
https://stackoverflow.com/questions/9419611/how-to-refer-to-embedded-resources-from-xaml
BR,
Daniel
(btw: your issue is more WPF than Inventor, so it were better placed on SO)
Message 10 of 17
thx daniel first link handles the issue.
I appreciate your help.
Message 11 of 17
dba78
I'm glad I could help 🙂
Message 12 of 17
2019mmp003
HI @AlexFielder , I tried referring your code for my c# addin.
SCDockWindow sc = new SCDockWindow();
Inventor.UserInterfaceManager oUserInterfaceMgr = m_inventorApplication.UserInterfaceManager;
WindowInteropHelper helper = new WindowInteropHelper(sc);
Inventor.DockableWindow oDockWindow = oUserInterfaceMgr.DockableWindows.Add(Guid.NewGuid().ToString(), "iSOlarconfig", "iSolarCOngilas");
SCDockWindow is a wpf page
In the underlined it shows an error indicating that we cannot convert SolarConfigurator.SCDockWindow to System.windows.window
Can I get a solution for this.
Message 13 of 17
yan.gauthier
I have myself several WPF windows in my addin. If it doesn't matter to you that you have the ability to dock the window, here how:
In the button class:
  • on the click event, Create a new thread and create your window instance in it (you want your own UI thread)
  • Store the ContextDispatcher of the UI thread on a private variable (you need this to send/post to the UI thread from the Inventor Thread)
  • From the UI thread, subsbribe to events (best way I found to send data from UI thread to Inventor Thread. Just defined some custom eventArgs class to passs whatever you want)
  • Outside the new thread declaration, store the CurrentDispatcher (Inventor's). you will use it to Invoke/BeginInvoke methods to the Inventor Thread
You can set the window to be top of Inventor so you have something similar to a dockable window by making the Inventor application the owner of the window :
var helper = new WindowInteropHelper(WPFWindow);
                        helper.Owner = new IntPtr(AddInServer.InvApp.MainFrameHWND);
Message 14 of 17
2019mmp003
@yan.gauthier Can you please provide me some reference code for this! It would be of great help! Thanks!!
Message 15 of 17
2019mmp003
Also, when until the wpf window is open, we cannot use any other inventor buttons, how can we use both the window buttons as well as inventor options simultaneously?
Message 16 of 17
dba78
in dockableWindow you will need a ElementHost (generally spoken, to show WPF Content in Forms-Container).
See:
https://adndevblog.typepad.com/manufacturing/2012/06/embedding-a-wpf-user-control-in-a-dockablewindo...
Message 17 of 17
yan.gauthier
LoadPropForm here is my WPF window object. It follows the MVVM structure. the ViewModel contains the event to be subscribed to
override protected void ButtonDefinition_OnExecute(NameValueMap context)
            mainThreadDispatcher = Dispatcher.CurrentDispatcher;
            // Create a thread
            if (!loadPropOpen)
                //Must have an activeEditDocument to run
                if (AddInServer.InvApp.ActiveEditDocument is Document document)
                    Thread newWindowThread = new Thread(new ThreadStart(() =>
                        // Create our context, and install it:
                        syncContext = new DispatcherSynchronizationContext(Dispatcher.CurrentDispatcher);
                        SynchronizationContext.SetSynchronizationContext(syncContext);
                        LoadPropForm = new LoadPropForm(AddInServer.InvApp, mainThreadDispatcher.Invoke<PropModel>(() =>
                            //Instanciating this instance loads Divalto List async
                            DivaltoLazies divaltoUtilities = DivaltoLazies.Instance;
                            //get material and treatment lists
                            using (var genikAddinDbContext = new Db.GenikAddinDbContext(Constants.GenikAddinDataBaseConnectionString))
                                //includes treatments as well
                                materials = new ConcurrentBag<Db.Material>(genikAddinDbContext.Materials.Include(x => x.Treatments).ToList());
                            return new PropModel(document, materials.ToList());  //Create new propModel from inventor Thread
                        // When the window closes, shut down the dispatcher
                        LoadPropForm.Closed += (s, e) =>
                            mainThreadDispatcher.Invoke(() =>
                                AddInServer.InvApp.ApplicationEvents.OnActivateDocument -= ApplicationEvents_OnActivateDocument;
                            Dispatcher.CurrentDispatcher.BeginInvokeShutdown(DispatcherPriority.Background);
                            loadPropOpen = false;
                        //When Window is loaded reset mouse cursor
                        LoadPropForm.Loaded += (s, e) =>
                                Mouse.OverrideCursor = null;
                        ((ViewModel)LoadPropForm.DataContext).InventorUpdated += LoadPropButton_InventorUpdated;
                        //Run updating task from main thread
                        ((ViewModel)LoadPropForm.DataContext).SchematikPersistantUpdated += (s, e) =>
                                Document doc;
                                if (AddInServer.InvApp.ActiveEditDocument.FullDocumentName.Equals(e.DocumentName, StringComparison.CurrentCultureIgnoreCase))
                                    doc = AddInServer.InvApp.ActiveEditDocument;
                                else
                                    doc = (from Document woo in AddInServer.InvApp.Documents
                                           where woo.FullDocumentName.Equals(e.DocumentName, StringComparison.CurrentCultureIgnoreCase)
                                           select woo).FirstOrDefault();
                                if (doc != null)
                                    InventorMethods.UpdateCustomProperty(e.ChangedValue, doc, e.PropertyName);
                                else
                                    throw new Exception($"la composante {System.IO.Path.GetFileName(e.DocumentName)} n'est pas ouverte.");
                                //DataControl.InventorExtension.UpdateCustomProperty(e.ChangedValue, AddInServer.InvApp.ActiveEditDocument, e.PropertyName);
                        //Print single document from main Inventor Thread
                        ((ViewModel)LoadPropForm.DataContext).PrintDrawingEvent += (s, e) =>
                                if (InventorMethods.CompareWithVault(e.Model.FilePath))
                                    InventorMethods.PrintSingleDrawing(e.Model, e.Settings, e.Quantity);
                        //Setting up Owner makes the windows over its owner only
                        var helper = new WindowInteropHelper(LoadPropForm);
                        LoadPropForm.Show();
                        //LoadPropForm.Topmost = true; //always first
                        loadPropOpen = true;
                        // Start the Dispatcher Processing
                        System.Windows.Threading.Dispatcher.Run();
                    // Setup and start thread as before
                    newWindowThread.SetApartmentState(ApartmentState.STA);
                    newWindowThread.IsBackground = true;
                    //Display wait cursor
                        Mouse.OverrideCursor = Cursors.Wait;
                    newWindowThread.Start();
                    AddInServer.InvApp.ApplicationEvents.OnActivateDocument += ApplicationEvents_OnActivateDocument;
        private void LoadPropButton_InventorUpdated(object sender, InventorPropertyEventArgs e)
                Document doc;
                else
                if (doc != null)
                else
                    //fire once ?
                    MessageBox.Show($"la composante: {System.IO.Path.GetFileName(e.DocumentName)}{System.Environment.NewLine}n'est pas ouverte. Les changements sont perdus.", "PropModel", MessageBoxButton.OK, MessageBoxImage.Exclamation, MessageBoxResult.OK, MessageBoxOptions.DefaultDesktopOnly);
        //Update LoadProp info when active document change
        private void ApplicationEvents_OnActivateDocument(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
            HandlingCode = HandlingCodeEnum.kEventNotHandled; // Let inventor do his things
            if (BeforeOrAfter == EventTimingEnum.kAfter)
                if (materials == null)
                //Generate PropModel on Inventor thread, then send it to UI
                //PropModel propModel = new PropModel(DocumentObject, materialDataSource.ToList(), traitementMateriel.ToList());
                PropModel propModel = new PropModel(DocumentObject, materials.ToList());
                syncContext.Post(o =>
                    ((ViewModel)LoadPropForm.DataContext).InventorUpdated -= LoadPropButton_InventorUpdated;
                    LoadPropForm.ReloadViewModel(DocumentObject, propModel);
                }, null);
                syncContext.Post(o => ((ViewModel)LoadPropForm.DataContext).InventorUpdated += LoadPropButton_InventorUpdated , null);
            else if (BeforeOrAfter == EventTimingEnum.kBefore)
                //Validate if there are pending changes
                //If yes, check if the document is still opened
                bool needToSaveDocumentChanges = false;
                string fileName = "";
                syncContext.Send(o => ((ViewModel)LoadPropForm.DataContext).CheckPendingChanges(ref needToSaveDocumentChanges, ref fileName), null);
                if (needToSaveDocumentChanges)
                    //Check if filename still exists:
                    if((from Document doc in AddInServer.InvApp.Documents
                           where doc.FullDocumentName.Equals(fileName, StringComparison.CurrentCultureIgnoreCase)
                           select doc).Any())
                        //post is fire and forget !
                            ((ViewModel)LoadPropForm.DataContext).Model.AcceptChanges();
                            ((ViewModel)LoadPropForm.DataContext).SchematikData.UpdateInventor();
                            ((ViewModel)LoadPropForm.DataContext).SchematikData.AcceptChanges();
                        }, null);
                    else
                        MessageBox.Show($"Le document: {System.IO.Path.GetFileNameWithoutExtension(fileName)}{System.Environment.NewLine}A été fermé. Les changements ont été perdus", "PropModel", MessageBoxButton.OK, MessageBoxImage.Exclamation, MessageBoxResult.OK, MessageBoxOptions.DefaultDesktopOnly);
