WorkPlaneProxy error
I have the following code that is giving me fits. I am trying to constrain a part. It Fails at oPart.CreateGeometryProxy() the error is
"Type mismatch. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))" For some reason it does not like oProxyPlane.
Thanks in advance
Kevin
SyntaxEditor Code Snippet
Dim oAsmDoc as AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
'set references for Assembly planes
Dim oMasterPlaneYZ As WorkPlane = oAsmCompDef.Workplanes(1)
'Dim oMasterPlaneXZ As WorkPlane = oAsmCompDef.Workplanes(2)'Dim oMasterPlaneXY As WorkPlane = oAsmCompDef.Workplanes(3)
Dim oPart = ComponentOccurence
oPart = oAsmCompDef.Occurrences.Item(1)
oPart.Grounded = False
' define part planes
Dim oPartPlane As WorkPlane = oPart.Definition.WorkPlanes(1)
' define proxies
Dim oProxyPlane As WorkPlaneProxy = Nothing
Call oPart.CreateGeometryProxy(oPartPlane, oProxyPlane)
Call oAsmCompDef.Constraints.AddMateConstraint(oMasterPlaneYZ, oProxyPlane, 0)
JaneFan
Hey @Anonymous,
You code looks good, but one line need be changed. Please have a try with one-line-updated code as below:
Code Snippet
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oMasterPlaneYZ As WorkPlane = oAsmCompDef.WorkPlanes(1)
Dim oPart  As ComponentOccurrence
' define proxies
Jane Fan
Inventor/Fusion QA Engineer
