Saving hole configurations.
We have a need to reuse the same holes over and over again in
different components.
Is there a way to create saved holes or favorite holes so
we do not have to fill out the dialog box every time?
Have you look at iFeature?
CCarreiras
Hi!
No... But, when you create a new hole, the tool will maintain the options of the latest used hole, and you can use the same specs for the next ones.
But... everytime we start the software, it resets to the standard options again.
Maybe they will change that soon, as this "issue" has been arise by several users.
CCarreiras
See below for info on how to use the clearance.xls and thread.xls, very useful to setup your own hole standards. See attached image.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Thank You this will work and save time.
