Why "0001test" is not a valid string?
Cris-Ideas
Advisor Advisor
Cris-Ideas
Hi
I have run on to something I do not understand.
This line of code works:
attr = occAttributeSet.Add("_0001test", ValueTypeEnum.kStringType, "test")
but when I replace string for attribute name with "0001test" that is is rising an exception.
So this does not work:
attr = occAttributeSet.Add("0001test", ValueTypeEnum.kStringType, "test")
Why 0001test is not a valid string?
Cris.
Cris,
https://simply.engineering
JaneFan
Hi @Cris-Ideas
AttributeSets.Add() seems don't accept attributeset name starting with a number for current behavior.
Jane Fan
Inventor/Fusion QA Engineer
Cris-Ideas
Yes,
That's the answer I got form customer support.
It would be much easier if this information was just given in help.
Perhaps you could contact people responsible for help so they just add this?
Cris
Cris,
