AttributeSet.Add method - how to add attribute
Cris-Ideas
Advisor Advisor
Cris-Ideas
I have a problem with adding attributes to an attribute set.
Attribute set was created and I can print its name, so I assume it is there
I now need to add attributes to the set.
But cannot get Add method to work.
Can someone en-light me how do I add attribute? (I need various types: string, byte array, boolean.)
I tried like this:
attr = occAttributeSet.Add("0001TopName", ValueTypeEnum.kStringType, SattrName)
and like this:
occAttributeSet.Add("0006DefaultInPre", ValueTypeEnum.kStringType, "Off")
But I am getting run time exception every time.
Cris.
Cris,
https://simply.engineering
martin.jacko
As first use attSet.NameIsUsed[attName] to check attribute with given name already exists.  Then check if attset is not null. Latest problem can be using attributeSets instead of attributeSet.
In inventor structure is AttributeSets-AttributeSet-Attribute.
Martin
Cris-Ideas
In this particular case it turned out that name of the attribute cannot start with digit.
Cris.
Cris,
AlexFielder
Useful to know, thanks for sharing!
