Why is Counting Holes so Slow?
etckerry
etckerry
I have written a routine to count the holes in a part.  It generates accurate counts, but it is incredibly slow - I can't figure out why.  Also, if I don't have the part checked out, it asks me if I want to check it out - I also cannot figure this out, since I am not modifying the document in any way.
It seems that the slow down and the "dirtying" occur at about the same place - on the "Continue For" lines in ProcessPattern.  Any ideas on either my speed issue or the dirtying issue?
I removed some code to clean up what needs to be shown here - consider the ProcessPart() method as the main function.
Public Class RivetCounter
    Private counts As New Hashtable
    Private Sub AddCount(ByVal diameter As Double, ByVal number As Integer)
        If counts.ContainsKey(diameter) Then
            counts(diameter) = CType(counts(diameter), Integer) + number
        Else
            counts(diameter) = number
        End If
    End Sub
    Private Sub ProcessPart(ByRef part As Inventor.PartDocument, ByVal quantity As Integer)
        Dim hole As Inventor.HoleFeature
        For Each hole In part.ComponentDefinition.Features.HoleFeatures
            ProcessHoleFeature(hole, quantity)
        Next hole
        Dim rectPat As Inventor.RectangularPatternFeature
        For Each rectPat In part.ComponentDefinition.Features.RectangularPatternFeatures
            ProcessPattern(rectPat.ParentFeatures, quantity * rectPat.PatternElements.Count, rectPat.ConsumeInputs)
        Next rectPat
        Dim circPat As Inventor.CircularPatternFeature
        For Each circPat In part.ComponentDefinition.Features.CircularPatternFeatures
            ProcessPattern(circPat.ParentFeatures, quantity * circPat.PatternElements.Count, circPat.ConsumeInputs)
        Next circPat
    End Sub
    Private Sub ProcessHoleFeature(ByRef hole As Inventor.HoleFeature, ByVal quantity As Integer)
        ' Apparently Inventor uses cm as internal units
        AddCount(hole.HoleDiameter.ModelValue / 2.54, quantity * hole.HoleCenterPoints.Count)
    End Sub
    Private Sub ProcessPattern(ByRef features As Inventor.ObjectCollection, ByVal quantity As Integer, ByVal consumeInputs As Boolean)
        Dim i As Integer
        For i = 1 To features.Count
            ' Try to process the feature as each of the types we are interested in
            ' On failures, continue trying the next type of feature
            ' On success, continue with the next feature object
            ' HoleFeature
            Try
                Dim hole As Inventor.HoleFeature = CType(features(i), Inventor.HoleFeature)
                If consumeInputs Then
                Else
                    ProcessHoleFeature(hole, quantity - 1)
                End If
                Continue For
            Catch ex As Exception
                ' Not a hole
            End Try
            ' RectangularPatternFeature
            Try
                Dim rectPat As Inventor.RectangularPatternFeature = CType(features(i), Inventor.RectangularPatternFeature)
                Else
                    ProcessPattern(rectPat.ParentFeatures, quantity * (rectPat.PatternElements.Count - 1), rectPat.ConsumeInputs)
                End If
                Continue For
                ' Not a rectangular pattern
            End Try
            ' CircularPatternFeature
            Try
                Dim circPat As Inventor.CircularPatternFeature = CType(features(i), Inventor.CircularPatternFeature)
                Else
                    ProcessPattern(circPat.ParentFeatures, quantity * (circPat.PatternElements.Count - 1), circPat.ConsumeInputs)
                End If
                Continue For
                ' Not a circular pattern
            End Try
        Next i
    End Sub
End Class
Thanks for your help!
-Kerry
ekinsb
Wow, this was a tricky one to find.  Change your declaration of
to
Private Sub ProcessPattern(ByVal features As Inventor.ObjectCollection, ByVal quantity As Integer, ByVal consumeInputs As Boolean)
It was reassigning the set of parent features for the pattern every time the sub returned.
Brian Ekins
Mod the Machine blog
j.romo
Can you share the whole code?Smiley Happy
