Compare colors
Compare colors
TONELLAL
Compare colors
TONELLAL
I need to override part color with default renderstyle color. So I get the default render style color (only the Ambient color), create a color based on RGB values, and compare with reference colors to use a Select case. But I cannot differentiate 2 colors created with CreateColors. Where is the problem ?
Dim oDoc As PartDocument
Dim couleur As Color, colRed As Color, colGreen As Color
Dim rr As Byte, gg As Byte, bb As Byte
Set oDoc = ThisApplication.ActiveDocument
oDoc.RenderStyles.Item("Par défaut").GetAmbientColor rr, gg, bb
'Create the color
Set couleur = ThisApplication.TransientObjects.CreateColor(rr, gg, bb)
'Create reference colors
Set colRed= ThisApplication.TransientObjects.CreateColor(255, 0, 0)
Set colGreen = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
'Compare
select case couleur  'ALL THE CASES ARE TRUE !
case colRed
case colGreen
end select
philippe.leefsma
Hi There,
You cannot use an object as a Select/Case paramater, only Integer/String/Bool are supported I believe.
You would need to create your own color comparison method by checking each property to see if they are equal, Color.Red, Green, Blue, Opacity.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
