why does icon on buttons not always work(Marco) ?
Darkforce_the_ilogic_guy
Advisor Advisor
anyone know why I can´t get icon on all my marco buttons?
If i use the liltte icon it work if i use the large icon.. it does not
JhoelForshav
Hi @Darkforce_the_ilogic_guy
Make sure the dimensions of the image is 32x32 and the bit depth is not more than 24.
You can check this by right clicking the bmp-file, select properties and go to details tab.
_dscholtes_
I'm going to assume you have the naming and icon sizing right.
I sometimes have the same issue when I save an icon as 32-bit file or let paint.net auto-detect the bit depth. Saving it as 24-bit file resolves the issue for me.
[edit] I see the correct answer has been given in the mean time [/edit]
bradeneuropeArthur
Comment removed since you have already checked my remarks.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
