Which .NET version for Add-Ins does Inventor 2023 support?
verena_liewaldMU2Q9
Observer Observer
verena_liewaldMU2Q9
Observer
Observer
I have some problems upgrading my C# Inventor Add-In (with my own Ribbon Tabs etc.) from .NET 4.8 to .NET 6. I am using Inventor 2023. Looking up in the Inventor.exe.config, I found .NET 4.8. Does that mean that .NET 6 is not possible to use? Or can I manually manipulate this file?
In the conversation  Inventor .NET 6 Add-In (.NET Core followup version) - Autodesk Community - Inventor
I found some issues about Inventor.Documents (@Andrew.WhiteBEDAD). Is that still a problem?
Thank you for your help.
<startup useLegacyV2RuntimeActivationPolicy="true">
    <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.8"/>
  </startup>
bradeneuropeArthur
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
