Where Did I went Wrong
Boopathi_Sivakumar
Message 1 of 10
Boopathi_Sivakumar
Hello Guys,
I have started to Learn API for inventor. I am stuck with the bunch of codes . I Don't Know Where i Went wrong it throws me an error. I have tried lots of methods everything seems not working.
I been try to code it in Visual Studio but this one i have tested in the rule itself it is not working
i found the problem with the profiles, But don't know how to resolve it
Dim App As Inventor.Application
App = ThisApplication
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
 Dim oCd As PartComponentDefinition
 Dim oTg As TransientGeometry
 oCd = oDoc.ComponentDefinition
        oTg = App.TransientGeometry
        Dim Ske As PlanarSketch
        Ske = oCd.Sketches.Add(oCd.WorkPlanes.Item(3))
        Dim oPo(7) As Point2d
        oPo(0) = oTg.CreatePoint2d(0, 0)
        oPo(1) = oTg.CreatePoint2d(5, 0)
        oPo(2) = oTg.CreatePoint2d(5, 2)
        oPo(3) = oTg.CreatePoint2d(4, 2)
        oPo(4) = oTg.CreatePoint2d(4, 3)
        oPo(5) = oTg.CreatePoint2d(5, 3)
        oPo(6) = oTg.CreatePoint2d(5, 5)
        oPo(7) = oTg.CreatePoint2d(0, 5)
        Dim Sk(7) As SketchLine
        Sk(0) = Ske.SketchLines.AddByTwoPoints(oPo(0), oPo(1))
        Sk(1) = Ske.SketchLines.AddByTwoPoints(Sk(0).EndSketchPoint, oPo(2))
        Sk(2) = Ske.SketchLines.AddByTwoPoints(Sk(1).EndSketchPoint, oPo(3))
        Sk(3) = Ske.SketchLines.AddByTwoPoints(Sk(2).EndSketchPoint, oPo(4))
        Sk(4) = Ske.SketchLines.AddByTwoPoints(Sk(3).EndSketchPoint, oPo(5))
        Sk(5) = Ske.SketchLines.AddByTwoPoints(Sk(4).EndSketchPoint, oPo(6))
        Sk(6) = Ske.SketchLines.AddByTwoPoints(Sk(5).EndSketchPoint, oPo(7))
        Sk(7) = Ske.SketchLines.AddByTwoPoints(Sk(6).EndSketchPoint, oPo(0))
        Dim oCol As ObjectCollection = App.TransientObjects.CreateObjectCollection
        oCol.Add(Sk(0))
        oCol.Add(Sk(1))
        oCol.Add(Sk(2))
        oCol.Add(Sk(3))
        oCol.Add(Sk(4))
        oCol.Add(Sk(5))
        oCol.Add(Sk(6))
        oCol.Add(Sk(7))
        Dim oPro As Profile
        oPro = Ske.Profiles.AddForSolid(True, oCol)
        Dim oRev As RevolveFeatures
        oRev = oCd.Features.RevolveFeatures
        Dim rev1 As RevolveFeature
        rev1 = oRev.AddFull(oPro, oCd.WorkAxes.Item(2), PartFeatureOperationEnum.kNewBodyOperation)
Boopathi
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
Replies (9)
Message 2 of 10
bradeneuropeArthur
The sketch seems to be not closed!
Why I don't know.
Your code seems to be ok!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
Jef_E
The profile isn't closed at the end. You can drag the last line away from the first.
I fixed the faulty line.
        Sk(7) = Ske.SketchLines.AddByTwoPoints(Sk(6).EndSketchPoint, Sk(0).StartSketchPoint)
        oCol.Add(Sk(0))
        oCol.Add(Sk(1))
        oCol.Add(Sk(2))
        oCol.Add(Sk(3))
        oCol.Add(Sk(4))
        oCol.Add(Sk(5))
        oCol.Add(Sk(6))
        oCol.Add(Sk(7))
        Dim oPro As Profile
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Message 4 of 10
Sergio.D.Suárez
Hi, What is wrong in the code is that there are no coincidences in the startpoint of the first line, and the end point of the second line. Then there is the open profile. With this code, it should work well. Look at the detail marked in red to define the last line generated.
        oCol.Add(Sk(0))
        oCol.Add(Sk(1))
        oCol.Add(Sk(2))
        oCol.Add(Sk(3))
        oCol.Add(Sk(4))
        oCol.Add(Sk(5))
        oCol.Add(Sk(6))
        oCol.Add(Sk(7))
        Dim oPro As Profile
 I hope this helps. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 5 of 10
Jef_E
@Sergio.D.Suárez community has changed it seems last time I asked a question it takes weeks for a answer now he gets 2 in 3min.
Inventor 2014 SP2
Message 6 of 10
Sergio.D.Suárez
Sorry, I assure you that I did not see your publication until after re-entering the publication. That was very close! I send you a warm greeting!
Mechanical Designer
Message 7 of 10
bradeneuropeArthur
I did not see this post till now/today!
What is the issue?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
Boopathi_Sivakumar
@Jef_E  @Sergio.D.Suárez
Thanks for the answer now i understand the problem, I am curious about how you guys find out the sketch is not closed it is it in the error page or by already faced this issue Smiley LOL
Cheers,
Boopathi
Boopathi Sivakumar
www.usamcadsoft.in
Message 9 of 10
bradeneuropeArthur
move the line manually!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 10
Sergio.D.Suárez
Copying only this segment of your code, then pulls as @bradeneuropeArthur mentions, and your sketch adjusts as the image shows
Mechanical Designer
