Where are CreateLinearPlacementDefinition and ReferencedFiles?
Stakin
Stakin
These days, it has been discovered that the following two interface functions cannot be found in Inventor API 2025
PartlistRow.ReferencedFiles
HoleFeatures.CreateLinearPlacementDefinition
Where can I find a more comprehensive interface introduction?
If these function is deleted, what was used as a substitute? thanks
WCrihfield
Hi @Stakin.  About the PartsListRow.ReferencedFiles property...I do not think that was ever a publicly available property for us to be using, because I do not recall ever seeing it in any Inventor API help documentation over the years.  I think that was just a 'Hidden' Property within the PartsListRow Interface which was meant for 'internal use' (for supporting the functionality of the source code behind the API object and its properties/methods), rather than for public use.  Someone likely just did some 'Reflection' type snooping into these objects to find these types of hidden properties, looking for a shortcut.  The folks at Autodesk warn us against using these types of properties, because they may be unstable, which means they may change in name. functionality, or cease to exist, at any time.  A single row in a PartsList is generally only going to be referencing a single file on disk, but potentially multiple components within an assembly that all reference the same file.  There are exceptions to this, but that is the norm.  You would normally have to step multiple steps deeper to get to file references, starting with PartsListRow.ReferencedRows and going on from there.  I have shown a few examples of this in this forum before, and I'm sure others have also.
As for the HoleFeatures.CreateLinearPlacementDefinition method...I know it was there in the 2024 online API help, but I do not see it in the 2025 online API help.  I am not sure if it just got hidden (either on purpose, or by mistake), or if they officially got rid of it.  I do know that in the past, some properties/methods have been hidden by mistake, then later unhidden, but not sure.  You could test for this though, by trying to use it, even though it may not be showing any 'Intellisense' hints about it.  If it still works, then we would know that it just got hidden, but is still there, and still works.  This may be something to ask someone at Autodesk about directly, because the rest of us would not know for sure until we hear from them.
Wesley Crihfield
(Not an Autodesk Employee)
