Hi there,
Is there a way to add weld beads in weldment assembly by using iLogic? I work on templates which are added to assembly and then i have to add welds by hand, so I was wondering if there maybe is an option to name entities in those parts and then run a code in assembly to create weld bead between two surfaces? Those are usually repeatable models so i would prepare few rules and run those which would be needed in specific cases.
I've tried to do it but i can't find in any welds classes an "add" option - only edit or delete.
