Message 1 of 1
Loft using profiles in the same 3D sketch - using VBA
Hello people.
I am trying to do a VBA code to automate the following steps:
1- import an excel spreadsheet points to a 3d sketch and generate some splines passing through the points that are in the same section. After that I close the spline with a straight line.
2- use the closed sections generated by spline+line in each section to be loft profiles.
Step 1 is working, but step 2 isn't. I will attach my code here. I could create the profiles and everything, but it ends up in an error with the last loft command (line 111). Code is below:
Sub testing()
Dim invApp As Inventor.Application
Set invApp = ThisApplication
' Open new part document
Dim invDoc As Inventor.PartDocument
Set invDoc = invApp.Documents.Add(kPartDocumentObject, invApp.FileManager.GetTemplateFile(kPartDocumentObject))
Dim CompDef As PartComponentDefinition
Set CompDef = invDoc.ComponentDefinition
' Start new 3D Sketch
Dim inv3DSketch As Inventor.Sketch3D
Set inv3DSketch = invDoc.ComponentDefinition.Sketches3D.Add
' Address of the spreadsheet with data
Dim filePath As String
filePath = "C:\Path\to\your\output.xlsx" ' Update with your generic output file path
' Create and manipulate Excel object
Dim xlApp As Excel.Application
Dim xlWb As Excel.Workbook
Dim xlWs As Worksheet
Set xlApp = CreateObject("Excel.Application")
Set xlWb = xlApp.Workbooks.Open(filePath)
Set xlWs = xlWb.Sheets(1)
xlApp.Visible = False
' Read points from Excel
Dim row As Integer
row = 1
Dim firstPoint As Variant
Dim currentPoint As Variant
Dim pointsColl As ObjectCollection
Set pointsColl = invApp.TransientObjects.CreateObjectCollection
Dim flag As Integer
Dim sections As ObjectCollection
Set sections = invApp.TransientObjects.CreateObjectCollection
inv3DSketch.Edit
Do While xlWs.Cells(row, 1) <> ""
flag = 0
' Save current point
pointX = xlWs.Cells(row, 1)
pointY = xlWs.Cells(row, 2)
pointZ = xlWs.Cells(row, 3)
Set currentPoint = invApp.TransientGeometry.CreatePoint(CDbl(pointX) * 100, CDbl(pointY) * 100, CDbl(pointZ) * 100) ' Unit conversion
' Set initial point if starting a new section
If IsEmpty(firstPoint) Then
Set firstPoint = currentPoint
flag = 1
' Save current point in collection if not first or last point
If flag = 1 Or (currentPoint.X = firstPoint.X And currentPoint.Y = firstPoint.Y And currentPoint.Z = firstPoint.Z And pointsColl.Count > 0) Then
' Ignore first and last point
Else
pointsColl.Add currentPoint
If currentPoint.X = firstPoint.X And currentPoint.Y = firstPoint.Y And currentPoint.Z = firstPoint.Z And flag <> 1 Then
' Remove first 15 and last 15 points
If pointsColl.Count > 30 Then
Dim tempColl As ObjectCollection
Set tempColl = invApp.TransientObjects.CreateObjectCollection
Dim i As Integer
For i = 16 To pointsColl.Count - 15
tempColl.Add pointsColl.Item(i)
Next i
Set pointsColl = tempColl
' Add line connecting new first to new last point
If pointsColl.Count > 1 Then
Dim newFirstPoint As Point
Dim newLastPoint As Point
Set newFirstPoint = pointsColl.Item(1)
Set newLastPoint = pointsColl.Item(pointsColl.Count)
Dim line As SketchLine3D
Set line = inv3DSketch.SketchLines3D.AddByTwoPoints(newFirstPoint, newLastPoint)
' Create spline
Dim spline As Inventor.SketchSpline3D
Set spline = inv3DSketch.SketchSplines3D.Add(pointsColl)
' Create a profile for each closed section and add to sections collection
Dim Profile As Profile3D
Set Profile = inv3DSketch.Profiles3D.AddOpen
sections.Add Profile
' Clear for next section
firstPoint = Empty
pointsColl.Clear
flag = 0
row = row + 1
Loop
inv3DSketch.ExitEdit
' Create loft surface using profiles
Dim LoftDef As LoftDefinition
Set LoftDef = CompDef.Features.LoftFeatures.CreateLoftDefinition(sections, kSurfaceOperation)
CompDef.Features.LoftFeatures.Add LoftDef
' Close Excel without saving
xlWb.Close False
Set xlWb = Nothing
' Quit Excel
xlApp.Quit
Set xlApp = Nothing
MsgBox "Done!"
End Sub.
What I want is to import some sections and use to create a loft, like a variable diameter (or shape) pipeline. Hope someone could help me.
Thank you.
