What is the correct way to write these "parameter" equations in iLogic
chris
Advisor Advisor
chris
These work for me when I write them in the parameter window, but what is the correct way to write these within iLogic?
I'm not sure the correct way to write the (/1in), as the "in" causes problems within the code)
1.    acos((D1_b/1in)/(D1_c/1in))
2.    asin((D1_b/1in)/(D1_c/1in))
3.    sqrt(((D1_a/1in)^2ul)+((D1_b/1in)^2ul))*1in
(Above parameter names)  D1_a,   D1_b,   D1_c
chris
Okay, it looks like the iLogic equation is working, it's just giving me the answer in Radians, is there something I can add to the end of the iLogic equation that will convert to degrees?
chris
Nevermind, I figured it out
