Is there an iLogic code that can make a model sketch visible or not based on the sketch name
chris
Advisor Advisor
chris
Is there an iLogic code that can make a model sketch visible or not based on the sketch name and maybe a true/false parameter?
I'm working on a "calculator of sorts that is in one of my part files and I need to be able to show visibility of certain sketches if that is possible.
A.Acheson
Hi @chris
What you need is to set a planar sketch  visible. So navigate to API help and objects page for planarsketch here find the planar sketch object and check the property for visible.
Syntax
PlanarSketch.Visible() As Boolean
For the second task you can check the name of the sketch via the name property here
Syntax
PlanarSketch.Name() As String
Here is the VBA sample to set all sketches visible or not so you can adapt to filter the named sketch as required.
Regards
Alan
