What is the best way to rename (file name, iProp Part number and browser display name) Frame Generator parts?
chris
Advisor Advisor
chris
So I was running a test this morning to try and manage the changing of a frame Generator "weldment". I was using Design Assistant and everything seemed to be going fine, I renamed to the file name scheme I wanted and then opened the assy. and noticed that while the file name and iProp part number changed... I was still seeing the original Frame Generator browser names in the model browser... how can I access the browser name in Design Assistant to match the file name, "or" is there an iLogic code that will change the browser names to match the file names?
bradeneuropeArthur
In the assembly you can choose rename under the assembly tools tab.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
chris
@bradeneuropeArthur  I'd like to think I'm reading this right, but where do you see "Rename" in the Assembly tools tab?
bradeneuropeArthur
Under productivity.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
chris
@bradeneuropeArthur  AWESOME!!! thanks
chris
@bradeneuropeArthur okay, that was easy, what that "button" really needs, is the functionality of Design Assistant, so you can either just rename to file names or change the file name right there.
