what can cause this error ?
Darkforce_the_ilogic_guy
Advisor Advisor
I can this error when using form.  why does this come. at the end of the ilogic code have run
I do not know if it is the form or the ilogic code that makes the error but the name of the error is the same as the form dialog box of the form
bradeneuropeArthur
Please click detail and post this to investigate.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
