Ways to shorten iLogic running time & to stop while iLogic is running
wenhao.leowSLUZJ
wenhao.leowSLUZJ
Just want to ask if there's any way to shorten iLogic running time? And also, because the iLogic running too long, are there any way to stop when the iLogic is running? Really appreciate the help!
A.Acheson
Could you provide more information on what the rules are doing. Some images and dezcriptions of the task being carried out and the code which is being used. Generally there is no magic button to exit a rule but you could build in checks along the way to exit if certain criteria is met.
Regards
Alan
wenhao.leowSLUZJ
Thank you for the reply.
'Generally there is no magic button to exit a rule but you could build in checks along the way to exit if certain criteria is met.' May I know how to build in the checks? Thank you.
Wen Hao
A.Acheson
This would all depend on what your processing. Can you provide an ilogic rule and the issues it has such as takes too long or is freezing etc. The methods could involve counters, timers or error checks.
Regards
Alan
JelteDeJong
Without any details of your rule, it's in possible to say anything about your rule specific. But in general you may want to read this "Improving Your Program’s Performance".
Stopping a rule is complicated, but there is a "not so magic" button on the progress bar.
Have a look at the following example rule.
Class ThisRule
    Private _progressBar As Inventor.ProgressBar
    Private _userClickedOnCancel As Boolean = False
    Public Sub Main()
        _progressBar = ThisApplication.CreateProgressBar(False, 10, "This is your main title", True)
        AddHandler _progressBar.OnCancel, AddressOf OnCancel
        UpDateProgress("Executing first process")
        System.Threading.Tasks.Task.Delay(3000).Wait()
        For i = 2 To 10
            UpDateProgress("Executing some process: " & i)
            System.Threading.Tasks.Task.Delay(1000).Wait()
            If UserWantsToCancel Then Return
        Next
        _progressBar.Close()
    End Sub
    Private Property UserWantsToCancel() As Boolean
        Get
            If (_userClickedOnCancel) Then
                MsgBox("User clicked cancel and it has been detected now.")
                ' add code here for clean exit of the rule.
                Return True
            End If
            Return False
        End Get
        Set(value As Boolean)
            _userClickedOnCancel = value
        End Set
    End Property
    Private Sub UpDateProgress(message As String)
        _progressBar.Message = message
        _progressBar.UpdateProgress()
    End Sub
    Private Sub OnCancel()
        MsgBox("OnCancel fired. Setting UserWantsToCancel flag.")
        UserWantsToCancel = True
    End Sub
End Class
Notice the last boolean in the progress bar initialisation line:
 The default value (if you don't set it,) is "False". But by setting it to "True" you will get the cancel button on the progress bar. By default, nothing happens when the user clicks on that button and you have to code that all yourself. Therefore I added an event handler "OnCancel". This event handler will set the property "UserWantsToCancel" to "True". That will not stop the rule but at least we now have a property that will tell if the user wants to cancel.
Now in your code, you need to check if that property is set to "True". If that is the case then you need to stop(/return) your rule. This is done in the example with the line:
Jelte de Jong
Blog: hjalte.nl - github.com
