Want's to add one simpel calculation into iLogic, but how?
BRLMCHKD
BRLMCHKD
bradeneuropeArthur
Could you please explain a little more?
What do you need and what do you want to do?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
BRLMCHKD
bradeneuropeArthur
Public Sub main()
Dim LinerDia As Double
LinerDia = 114.3
Dim LinerTck As Double
LinerTck = 11
Dim LinerDiaMacnhinedMin As Double
Dim LinerDiaMacnhinedMax As Double
LinerDiaMacnhinedMin = LinerDia - 2 * (LinerTck * 0.7)
LinerDiaMacnhinedMax = LinerDia - 2 * (LinerTck * 0.2)
MsgBox LinerDiaMacnhinedMin
MsgBox LinerDiaMacnhinedMax
Dim result As Double
result = InputBox("Choose between ")
If result < LinerDiaMacnhinedMax And result > LinerDiaMacnhinedMin Then
Else
MsgBox result
End Sub
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
