Wait add in from loading
bradeneuropeArthur
Mentor Mentor
Message 1 of 10
bradeneuropeArthur
Is there a way to wait a custom add in from loading till for example the vault add in is loaded in inventor?
Regards.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (9)
Message 2 of 10
Rene_Gerlach
Hi @bradeneuropeArthur,
don't know what you want achive.
May be you connect to the ApplicatonEvents and wait for OnReady. At this time the vault addin may loaded.
Cheers
Rene
Message 3 of 10
bradeneuropeArthur
I want the custom add in to wait for loading till the vault add in is loaded. Or I want to load the custom add in as latest.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 10
Rene_Gerlach
I understand this.
But what is the background why you need the vault addin loaded before yours?
OnReady didn't solve your requirement?
You can also set the clsid of your addin to a higher value as the vault addin.
Cheers
Rene
Message 5 of 10
bradeneuropeArthur
The higher is I already know.
The reason is that my add in needed the vault add in for login to the vault.
I am not sure if the higher id is working for 2018. And what is the highest id of all add in id's is the question...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 10
Rene_Gerlach
Hm, is it really needed soon after loading to login into vault?
May be you can login in OnReady Event?
Cheers
Rene
Message 7 of 10
bradeneuropeArthur
On ready than I can't load an add in anymore!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
bradeneuropeArthur
Or I need to do it manually. That is not my idea. I need the add in loaded automatically, and use the credentials of the vault add in of inventor.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 10
marcin_otręba
instead doing that maybe just add in you activation code some checking if vault addin is activated, and if not just activate it ?
you can use this code for getting correct addin id.:
Private Sub addin_id()
  Dim DXFAddIn As TranslatorAddIn
    Set DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
For i = 1 To ThisApplication.ApplicationAddIns.Count
Debug.Print ThisApplication.ApplicationAddIns.Item(i).ClassIdString
Next
End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 10 of 10
bradeneuropeArthur
@Rene_Gerlach
That is what I needed and misunderstood the idea.
Thanks.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
