VS 2017 .addin File Origin
tdant
tdant
I'm new to VB.NET development, and I have a question. I'm working on putting together a .msi for my finished project. I know where to put the files for drop-in deployment, but I'm having trouble figuring out what part of the project's output contains the .addin file. I want to put the .addin where the red line is on the attached .png.
What part of the project output do I use? My options are: Primary output, Localized resources, Debug Symbols, Content Files, Source Files, Documentation Files, XML Serialization Assemblies, and Runtime Implementation. I've looked through the outputs of all those, and I don't see any .addin, but the .addin is in the source repository.
bradeneuropeArthur
The following:
The .addin file to: C:\ProgramData\Autodesk\Inventor ####\Addins
The Dll file to: C:\Program Files\Autodesk\Inventor ####\Bin
 How to Register/Unregister
 1) Build Project;
 2) Copy add-in dll file to one of following locations:
  a) Anywhere, then *.addin file <Assembly> setting should be updated to the full path including the dll name
  b) Inventor <InstallPath>\bin\ folder, then *.addin file <Assembly> setting should be the dll name only: <AddInName>.dll
  c) Inventor <InstallPath>\bin\XX folder, then *.addin file <Assembly> setting shoule be a relative path: XX\<AddInName>.dll
 3) Copy.addin manifest file to one of following locations:
  a) Inventor Version Dependent
  Windows XP:
   C:\Documents and Settings\All Users\Application Data\Autodesk\Inventor 2012\Addins\
  Windows7/Vista:
   C:\ProgramData\Autodesk\Inventor 2012\Addins\
  b) Inventor Version Independent
  Windows XP:
   C:\Documents and Settings\All Users\Application Data\Autodesk\Inventor Addins\
  Windows7/Vista:
   C:\ProgramData\Autodesk\Inventor Addins\
  c) Per User Override
  Windows XP:
   C:\Documents and Settings\<user>\Application Data\Autodesk\Inventor 2012\Addins\
  Windows7/Vista:
   C:\Users\<user>\AppData\Roaming\Autodesk\Inventor 2012\Addins\
 4) Startup Inventor, the AddIn should be loaded
 To unregister the AddIn, remove the Autodesk.<AddInName>.Inventor.addin from above mentioned .addin manifest file locations directly.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
tdant
Maybe my explanation was a little muddy. I know what directories to add the files to. I'm at the point now where I'm trying to build an installer file to put them there. What I need to know is which of the options in the red-circled box has the .addin file, so that I can stick it in the installer folder on the right, along with the .dll.
Alternatively, I can manually add the .addin file from the repository, but that means any changes will require that step again.
bradeneuropeArthur
I use ino setup compiler.
this is very easy to use and simple to understand.
What compiler do you use?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
tdant
I'm using Visual Studio Community 2017.
bradeneuropeArthur
You are not able to do this with Visual studio.
You need 2 file location.
That is why i use ino setup
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
