Visual Studio Inventor AddIn Template - Creating a New Ribbon Tab
j_chaissonQB25Y
j_chaissonQB25Y
this is for all you Code Guru's,
is there anyone out there that has modified the StandardAddInServer.vb file to add a new Ribbon Tab and then have your Panels and buttons reside there instead of using the Inventor default Ribbon Tabs?
Please don't respond with a hyperlink to Brian's AU document or his MOD blog. Yes I've seen them and have studied them unfortunately most of that is VBA.
Actual code snippets of a modified StandardAddInServer.vb would be great.
-Jeremy
WCrihfield
Hi @j_chaissonQB25Y.  I'm no expert in Add-Ins, but that actually sounds similar so one of the cababilities of @JelteDeJong 's Add-In named "Button Constructor".
http://www.hjalte.nl/inventor-addins/31-button-constructor
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=2268703737300536294&appLang=en&os=Win64
Maybe he would be able to help some with that, I'm not sure.
Wesley Crihfield
(Not an Autodesk Employee)
j_chaissonQB25Y
@WCrihfield ,
I have used his Addin before, I'm trying to take that next step in my automation and having Inventor Addins that's not iLogic based.
@JelteDeJong, I would really appreciate your help with this. you can message me directly and we can do a teams call if you would like.
-Jeremy
Frederick_Law
"IV Net AddIn Ribbon" is VS template.
"SaveThumb" is addin to save file thumbnail.
It add icon to new Ribbon Panel under "Tool".
You can see 2 added panels.  Spend more time making icons then coding the addin 🤣
JelteDeJong
Helping others on the forum is my hobby and I'm not a service provider therefore I don't do calls. But if you have questions that I can help you with just tag me and I will help if I can. For your opening question.
I will not give you links to AU classes or the site of Brian but I do have a link to a blog post. In that blog article, I describe how you can create an addin with Visual Studio/VB.net. Creating a button is also included in that post. (Although there is a separate post for adding icons to those buttons.) In the post, I also assume that you want to reuse ribbon tabs/panels from Inventor. If that is not the case you would need to change the "MyButton.AddButtonDefinitionToRibbon()". Insetad of using the item functions you should use the add functions something like this:
    Private Sub AddButtonDefinitionToRibbon()
        Dim ribbon As Ribbon = _inventor.UserInterfaceManager.Ribbons.Item("Assembly")
        Dim ribbonTab As RibbonTab = ribbon.RibbonTabs.Add("DisplayName", "InternalName", "ClientId")
        Dim ribbonPanel As RibbonPanel = ribbonTab.RibbonPanels.Add("DisplayName", "InternalName", "ClientId")
        ribbonPanel.CommandControls.AddButton(_settingsButton)
    End Sub
Now here are the links 🙂
http://www.hjalte.nl/tutorials/60-creating-an-inventor-addin
http://www.hjalte.nl/tutorials/61-adding-icons-to-your-buttons
and here you will find all the parts of the tutorial.
Jelte de Jong
Blog: hjalte.nl - github.com
