ilogic code to execute Drawing View command to reorient view
juha.marttilaXAEZL
juha.marttilaXAEZL
Hello Everyone,
Looking for iLogic code to activate "VIEW1" in drawing and execute the Drawing View
(like double clicking on drawing view) command so that I am able to reorient the view using the cube.
It seems like the code would include below?
ThisApplication.ActiveSheet.View("VIEW1")
CommandManager.ControlDefinitions.Item("DrawingBaseViewCmd").Execute
WCrihfield
Hi @juha.marttilaXAEZL.  I think the command you are looking for is "DrawingViewEditCtxCmd".  And to use that, you would first have to put that DrawingView object into the DrawingDocument.SelectSet, one way or another first.  Then execute the command.  But I am not sure you can add a DrawingView object directly into the SelectSet.  You may have to first get its BrowserNode, then use the BrowserNode.DoSelect, which will select that node for you, then execute that command.  You can get the BrowserNode using the DrawingDocument.BrowserPanes.Item("Model").GetBrowserNodeFromObject(oDrawingView).
Wesley Crihfield
(Not an Autodesk Employee)
juha.marttilaXAEZL
Hi @WCrihfield, Thanks for the feedback
Curtis_Waguespack
Hi @juha.marttilaXAEZL ,
Here's an example:
' Set a reference to the select set.
Dim oSelectSet As SelectSet
oSelectSet = ThisApplication.ActiveDocument.SelectSet
Dim doc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = doc.ActiveSheet
For Each oView As DrawingView In oSheet.DrawingViews
	If oView.Name = "VIEW1" Then
		oSelectSet.Select(oView)
		ThisApplication.CommandManager.ControlDefinitions.Item("DrawingViewEditCtxCmd").Execute
		Return
Next
 I hope this helps.
Curtis
juha.marttilaXAEZL
Hello  @Anonymous_Waguespac,
I sincerely appreciate your guidance, and I'm thrilled to report that your solution worked seamlessly and exactly as I envisioned. Thank you very much!
