Visual Basic.net program to extract iProperties
isocam
isocam
Can anybody help???
I am trying to write a simple Visual Basic.net (stand alone exe file) program to extract iProperties "Description" & "Revision Number form an Inventor ipt file, but I am having problems. Does anybody know how to do this?
I want, for purposes of testing, to call the ipt file "C:\Test.ipt"
Here is my code (I have added Inventor using "Import Inventor")....
Public Function GetPartData(PartDescription, PartRevision)
    Dim partDoc As PartDocument
    Set partDoc = ThisApplication.ActiveDocument
    Dim invDescriptionProperty As Property
    Dim invRevisionProperty As Property
    Set invDescriptionProperty = partDoc.PropertySets.Item("Design Tracking Properties").Item("Description")
    Set invRevisionProperty = partDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number")
    If invDescriptionProperty.Value <> "" Then
       PartDescription = invDescriptionProperty.Value
    Else
       PartDescription = ""
    End If
    If invRevisionProperty.Value <> "" Then
       PartRevision = invRevisionProperty.Value
    Else
       PartRevision = "-"
    End If
End Function
Many thanks in advance!!!!
IsoCAM
Ralf_Krieg
Hello
While running your addin as standalone exe you're not in Inventors context and can not get Inventor by ThisApplication. You can use ApprenticeServer if you only need to read iProp values.
Dim oApprentice As New Inventor.ApprenticeServerComponent
Dim oApprDoc As Inventor.ApprenticeServerDrawingDocument
oApprDoc = oApprentice.Open(yourfilenameasstring)
Or you get a reference to Inventor by something like this (this assumes a running inventor):
Dim oInventorApp As Inventor.Application
Dim oIVPart As Inventor.PartDocument
oInventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
oIVPart = oInventorApp.ActiveDocument
R. Krieg
RKW Solutions
www.rkw-solutions.com
