Visible sketch with ilogic (in an assemble)
Z0methink
Z0methink
This code is good:
Visible = True
prt = "Part:1"
sktch = "Sketch"
Dim compOcc = Component.InventorComponent(prt)
Dim oSk As PlanarSketch = compOcc.Definition.Sketches.Item(sktch)
Dim oSkProx As PlanarSketchProxy = Nothing
Call compOcc.CreateGeometryProxy(oSk, oSkProx)
oSkProx.Visible = Visible
This code gives an error message:
Sub Main()
Visible = True
prt = "Part:1"
sktch = "Sketch"
SketchVisible
End Sub
Sub SketchVisible()
End Sub
Message: "Component : The Component named "Nothing" was Not found."
 Why?
Z0methink
Sub Main()
Visible = True
prt = "Part:1"
sktch = "Sketch"
SketchVisible
End Sub
Sub SketchVisible()
End Sub
 Why?
andrewiv
If you want to use variables in multiple sub routines you have to pass them to the sub routine or make them global variables.  Here are the two ways of doing it.  I commented out the first part that shows passing the variables.
'Sub Main()
'Dim Visible As Boolean = True
'Dim prt As String = "Part:1"
'Dim sktch As String = "Sketch"
'	Call SketchVisible(Visible, prt, sktch)
'End Sub
'Sub SketchVisible(Visible As Boolean, prt As String, sktch As String)
'	Dim compOcc = Component.InventorComponent(prt)
'	Dim oSk As PlanarSketch = compOcc.Definition.Sketches.Item(sktch)
'	Dim oSkProx As PlanarSketchProxy = Nothing
'	Call compOcc.CreateGeometryProxy(oSk, oSkProx)
'	oSkProx.Visible = Visible
'End Sub
Class thisRule
Sub Main()
	Call SketchVisible()
End Sub
Sub SketchVisible()
End Sub
End Class
Andrew In’t Veld
Designer / CAD Administrator
marcin_otręba
Try now:
But honestly i do not now what you want to do?
Sub Main()
Visible = True
SketchVisible
End Sub
Sub SketchVisible()
prt = "Part:1"
sktch = "Sketch"
End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Z0methink
Thank you very very much! Works! I just simplified the code for ilogic (this worked too):
Sub main ()
Visible = True
prt = "Part: 1"
sktch = "Sketch"
SketchVisible (Visible, prt, sktch)
End sub
Sub SketchVisible (Visible As Boolean, prt As String, sktch As String)
Dim compOcc = Component.InventorComponent (prt)
Dim oSk As PlanarSketch = compOcc.Definition.Sketches.Item (sktch)
Call compOcc.CreateGeometryProxy (oSk, oSkProx)
End sub
Thanks!
Z0methink
I wanted to do something like this:
Sub main ()
Visible = True
prt = "Part: 1"
SketchVisible (Visible, prt)
Visible = True
prt = "Part: 2"
Visible = False
prt = "Part: 3"
End sub
Sub SketchVisible (Visible As Boolean, prt As String)
Dim oSk As PlanarSketch = compOcc.Definition.Sketches.Item ("Sketch")
End sub
