Unable to add ilogic
ramsuhas7
ramsuhas7
help me with this.
System.IO.FileNotFoundException: Could not find file 'C:\Users\USER\AppData\Local\Temp\f2rcm1fl.dll'.
File name: 'C:\Users\USER\AppData\Local\Temp\f2rcm1fl.dll'
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.File.InternalReadAllBytes(String path, Boolean checkHost)
at Autodesk.iLogic.Exec.AppDomExec.CompileCodeHere()
at Autodesk.iLogic.Exec.AppDomExec.CompileCodeInOtherDomain(AppDomain otherDomain, String codeName, String codeText, Boolean checkUnsafeCode)
at iLogic.RuleEvalContainer.ExecRuleCompile(String execRule)
mdavis22569
This isn't showing iLogic
What's the code you're trying to add....
Also for your error are all of your updates installed Inventor and Windows?
Mike Davis
DRoam
What are you doing when the message appears? Creating a new blank rule? Saving a rule? Running a rule?
